Question about Toshiba Satellite P25-S507 Notebook
Toshiba p25 will not see wireless networks
Great and fast just will not see wireless
works with cable
leon
Hdmi to rca pinout diagram
Hi McSamsung Throttle,
My old mate Leon did this and if you need further tech info check this image outlining the HDMI internal diagram below that)
http://leon-hacks.blogspot.co.uk/2012/06/xbox-360-rca-cable-hack-i-have-had-to.html
http://static.ddmcdn.com/gif/hdmi-connector-diagram.gif
Cheers
Apr 27, 2014 | Audio Players & Recorders
Seat leon engine
disconnect negative battery cable for about 15 min & reconnect
Apr 21, 2014 | 2000 Seat Leon
Low connectivity for d link 524 airplus g
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
May 25, 2012 | D-Link AirPlus G DI-524 Wireless Router -...
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
How do you hook up your netgear wireless router to your clear wire modem?
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Feb 25, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Gasket of head for subaru leone
Hello;
When the head gasket is changed, is the head resurfaced to make certain it is flat? Has anyone checked the block to make certain it is flat as well? Has the head been pressure tested to mak ecertain there is not a crack? That is what I would be looking at in your situation.
Hope this helps.
Thanks;
Rich
RPM Northwest
Jul 19, 2008 | 1990 Subaru Legacy
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Toshiba Satellite P25-S507 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
