Hi
This problem usually occurs with vista operating system.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%System32Catroot2 Catroot2.old
ren %systemroot%SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043” and install it.Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en Restart the computer once the update is installed.
Hope this solves your problem
hi lorshoe...
do you remember exactly what happened while you were installing the update? did your computer reboot while installing? normally it would try to recover the install.
can you boot into windows at all? there is a way to fix this, easier than you might think, if you can get into windows...
waiting to hear from you...
bru*
