Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Need schematic Kenmore bottom freezer model # 79565002401
I need a schematic for a Kenmore bottom freezer model # 79565002401 I have a report due on thursday and all I have is the machanical part done but I dont have the electrical part done
    President:
  • Kenmore Master
  • 2,651 Answers
You can pull off the kickplate(underrthe freezer door, and if you reach up under theright hand side there will be( if no one has removed it) a tech sheet/ wire diagram for you r machine
Posted on Mar 17, 2009
  • Bob Rakovic Jul 23, 2013
    Thanks for the tip! I did find the tech sheet, but it does not give me a picture of the back panel with in the freezer compartment. I may be looking for an illustrated repair manual. Can you help?
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I bought one disassembled, czn't figure out how to reassemble it
Please add model number. You can try searching using the model number. You could also try searching Sears.com for parts on the model number because it will bring up some schematics for you. IE: http://www.searspartsdirect.com/kenmore-refrigerator-parts/model-7678995880/0582/0163100.html?blt=06
Sep 01, 2015 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Why would our Kenmore refrigerator have an ice sheet at the bottom of the freezer and frequently leak water onto the floor?
sounds like a condensation problem due to plugged freezer drain line hole, need to remove bottom plate and have a closer look. if not that then check ur defrost terminator
Sep 06, 2014 | Kenmore Refrigerators
I have a Kenmore bottom freezer model 596.75934401. The refrigerator top has stopped cooling while the bottom freezer is working but showing some accumulation of icing. I have unplugged the regrigerator,...
There are a couple possibilities. You need to make sure the evaporator fan in the freezer is working, it circulates the cool air to the top. More likely your coil in the freezer is iced up due to defrost part failure, either the timer or the heater assembly. The back panel is going to have to come off. If you defrost the coil completely, the unit will work again until it ices up again. You have to have the defrost system diagnosed and the defective part replaced
Jun 25, 2011 | Kenmore Refrigerators
Water leaking from bottom of kenmore side by side fridge.
THE FREEZER MAY BE FROZEN UNDERNEATH THE COILS. UNPLUG THE KENMORE AND GET A VACUMM CLEANER OR A SHOP VAC AND CLEAN THE COILS ON THE BOTTOM OF THE FRIDGE. AFTER THAT REMOVE ALL ITEMS FROM THE FREEZER AND USE A SCREW DRIVER TO REMOVE THE PANELS FROM THE INSIDE OF THE FREEZER TO LOCATE THE COILS (INSIDE) THEY MAY NEED TO BE DEFROSTED DUE TO THE LENT BUILD-UP ON THE (UNDERSIDE) BOTTOM OF THE FRIDGE... HOPE THIS HELPS
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore freeze on the bottom.. model 596-72219200
Aug 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sears Kenmore bottom freezer/refrig #68142model
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
546 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
