Question about Edirol PCR-30 32-key Midi Keyboard Controller (EDIRPCR30)
Some keys not triggering when humidity low.
Some keys not triggering.Have to blow between cracks in keys for them to work.When humidity is higher in summer it is less of a problem.
What can I do to fix ths?
What is the cause?
Thanking you in advance
Brad
  • 3,153 Answers
You might want to try take a can of compressed air as used for computers and blow out any debris that may have built up.
See if that fixes it. You might also want to check out the editol web forums and ask in there as I am they might have more idea
Posted on Aug 08, 2009
Air blowes out the trigger when squezzed
the seal inside is ether out of place or cracked gun are cheap buy a new one
Jan 22, 2014 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
What are my humdity settings for DH504E Unit?
Simply put the humidity extraction settings generally range from 35% to 65%. The lower the percentage, the more humidity is removed and the house feels more comfortable. The higher the percentage, the more humidity remains in the house. In the hot humid Summer months, you want the humidity in the house to be as low as possible (i.e. 35%-45%) in the cooler months a higher humidity
( 60%) make the house feel more comfortable and does away with carpet static shock.
Choosing a setting is your decision, based on what I have explained above and your own comfort level.
I hope my information has helped you and thanks for choosing FixYa.
Aug 22, 2011 | Goldstar DH504EL Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
Our Goodman air conditioner (4 yrs old) is not removing humidity/moisture from inside our home. Last summer the drain from the ac drained moisture, this year it does not and we have a lot (35%) house...
35% humidity is very low. So low in fact that you should be waking up in the middle of the night for a drink of water and your wood furniture will dry out and crack. No idea how your testing the humidity level but your home should run around 50% relative humidity, that is most comfortable to human skin and is what we shoot for in a properly sized a/c system.
If it truly is too wet inside and you system is not pulling the moisture it should, you may have a low refrigerant level in your system or low air flow over the coil. How is the temperature and run time on the A/C? Is it running an unusually long time? Does it not keep up with a hot day? All of those symptoms could mean either low refrigerant or low airflow at the inside coil. Changed your filter lately?
Jun 16, 2011 | Goodman Heating & Cooling
How do you know if it is on?
Assuming that the unit is plugged in to an outlet that has power, press the ON button and a green light should come ON. That will indicate the unit is getting power and is ready to function. If however, you have the humidity level set to high and it's equal to or higher than the humidity level in your home, the unit's compressor and fan will not turn ON and run. Keep in mind, the humidity level, whether it's and LCD readout screen or just a minimum and high setting, that's not the amount of humidity that the unit will remove. It's what it will maintain. So, setting it as low as possible, should cause the unit to start functioning.
If it doesn't start, check the water collection bucket, to be sure that it's installed properly and is making contact with the safety trigger switch. If it's not making contact, the unit will not turn ON.
Hope this info helped you. Please let me know. Thanks.
May 13, 2011 | Amana D545M Dehumidifier
Just purchased a DeLonghi ev200 this afternoon, filled it up with water, switched it on and still not any cooler, if not hotter....please help, what am I doing wrong.
What yo describe sounds like a swamp cooler, which requires LOW HUMIDITY to actually work. The process of evaporation causes cooling.
If your humidity is not low enough, then you actually RAISE the humidity, and that makes your environment more uncomfortable.
The issue sounds like a physics issue and not the unit that you bought.... My thoughts is that if you live in a higher relative humidity area, units like yours should not be sold..... If you cannot actually evaporate, you will not cool.
Feb 20, 2011 | DeLonghi Heating & Cooling
Dew
dew means the humidity sensor
try to find a way to maked dry[like an air dryer set
to low or medium heat and fast speed fan
and blow air inside all crack in body cam
and let it rest for a while..]
hope that will help
regards Alan... watch to not be to close off the plastic body
hope that will help
regards Alan...
May 24, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
Hi I need help understanding the controls to my humidistat. I have a honeywell a/c unit so I'm assuming the gold colored humistat next to it is also honeywell. I bought a digital temperature and humitiy...
The higher the % of RH, (relative humidity), the more humid the house will be. I would disregard the temp part of the dial, and focus more on your comfort. Adjust it up daily until you reach a satisfactory humidity level. Hope this helps
Dec 19, 2009 | Honeywell Power Humidifier: Furnace...
1999 Ford f-150 blows hot air for ac
Sounds like a broken or cracked vacuum line under the hood.
May 24, 2009 | 1999 Ford F150 Regular Cab
Humidity reading is 16% when actual humidity is 46%
Running a dehumidifier when the ambient temperature is to low will cause freeze-ups. Also running it when the dew point of the moisture in the air is to low will cause it to freeze up when you set it to low which would be a higher number on the set point.
The hand written number on the probe casing is probably a quality control inspector number.
May 04, 2008 | Danby DDR586R Dehumidifier
Computers & Internet Logo
125 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Steven Burn
Steven Burn
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
