Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Standby indicator light on TV flashes - Sony TV
When TV switched on, indicator light flashes continuously. There is no picture or sound and remote control does not functionFX at all. TV is Sony FD Trinitron WIDE Colour Television (model KV-28FX68B or KV-32FX68B). Thanks for any help, Austin.I now have the same problem with no screen blinks 3 times slow then 7 times fast. before that it was a gren screen with two horizontal lines, sometimes after warming up i would get a pic n pic only about 1/3 of screen size for a couple hours
  • mcneese1 Mar 11, 2009
    Had it unplugged all day before I sent msg.
    Will give that a shot, need to find manual.
  • 790 Answers
Hi
This is power oscillation issue at HOT side section this trouble needs to diagnose...
thanks!
Posted on Mar 11, 2009
  • 728 Answers
If you still have the manual, look in it and see what it says the code of the blinking light says. It will usually give you an error code that we can work from there. This clarify the problem that needs to be fixed.
Posted on Mar 10, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Please revert for any clarification.
Thanks
Rylee
    Sergeant:
  • 300 Answers
Its the problem of the internal ic that has gone faulty on the main board.but it has to be checked properly with multimeter as this ic with itself also blows 1 or more two components.so all of the above it has to be checked with a proper professional but if the whole main board needs replacing .then its not worth getting it fixed but if only the ic replacemt then its worth fixing the tv/.
  • 4,234 Answers
I think that you may have a few problems here. If you can solder, we should be able to resolve them. First, resolder any connections that appear grainy or have rings. Once that is done, the symptoms should either go away or at least change. Please update this with the new symptoms and we'll continue from there.
Based upon the symptoms you've described, I think you have a problem with the vertical IC. Please try the resoldering first and update this.
Thanks,
Dan
  • 583 Answers
Unplug the tv for a while and then plug back in and check initially before we check out other issues.
  • 10,515 Answers
Even Sony is having some reliability problems with their video and tv products.
The continuous blink indication, as the link you pointed out indicates, is an IC problem. Probably the IC that contains the diagnostic routine in it; although I don't know that for sure.
The IC 301 mentioned in the link is what we call the Jungle chip; it is the main processing agency for the video, particularly the Y/C processing. It is a big, very complicated IC with over 50 pins. It could be the IC or something totally unrelated that the IC is merely monitoring. There are a host of functions manageed by the Jungle IC among which are automatic switching, buffering of video, S-video driver the R, G and B outputs - and one or more signals to the protection circuit....... if all that means anything to you.
So, what is the problem? It will require a deeper diagnostic investigation; preferrably by someone who can put hands on the set and do some testing and evalutating.
As a general rule, any time the blinking of the standby light occurs it is determined to be a major matter. Unless a simple hard reset cures it you can plan on it being a moderate to expensive repair.
The audible click is the relay switching power ON/OFF. The protection circuit is the controlling factor which tells the relay to turn the set off. It may be coming from the Jungle IC or somewhere else.
But the real question is whether to fix or replace. The set is getting along in years. As a rule of thumb, any set with a serious problem and is more than 3 or 4 years old is NOT a candidate for repair (unless it is known to be a trivial repair like a bad speaker or such).
Another rule that is used is this: If the repair cost is over 1/2 of the replacement cost for a similar set, then replace it.
Hope this is some help. Sorry I can't give you a precise prognostication. If IC 301 was known to be the culprit - and we don't know that for sure - then you would be into a major repair getting that ic out and doing the diagnostic routines after its replacement. I think the replacement of that IC will normally run around $150; probably $75 for the part alone.
Let me know if I can help further.
  • taran_2005
    taran_2005 Mar 10, 2009
    3 blinks....
    As a general rule, the blinking standby light means serious problems and you would be better off getting a technician involved.
    This set is a very expensive one and it has some life left in it. Further it is a Sony, so you will be wise to get it fixed.
    After studying the blinking codes, let me know if you have any further questions.
  • taran_2005
    taran_2005 Mar 12, 2009
    You can download the manual from
    http://support.sony-europe.com/manuals/m...
    Thanks.
Finlux tv showing black screen after switching on by remote. standby light is flashing buy mo picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Oct 08, 2016 | Finlux Televison & Video
I have a kdf-e42a10 tv no sound or picture red light flashes continuous
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Sony KDF-E42A10 42 in. LCD Television
Sony Trinitron Model KV20FV10- when I turn it on the Sound comes on BUT no picture and the red light for the Standby Times keeps flashing non-stop.
How many times do this standby light blinks. It is fault indications. You can get an idea about the faulty section inside the TV, by counting these blinks occurs at one time switch ON. These are called blinking codes. For more details about blinking codes to Sony brand TVs, check this link. Pull up older posts there. Surf the site with patience.
Mar 21, 2013 | Televison & Video
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a Sony Trinitron 32" TV. The picture don't
Hello
Blinking of standby light in Sony sets are fault indications. You just count the number of blinks occur at a time, by switching the set ON-OFF by its front panel power switch, not by the remote control handset. Just do it for at least three or four times, count the exact number of blinks occurs there, and inform it to me through Fixya. Through the number of blinks, I can locate the faulty section, of somtimes to the exact fault location. Count it keenly and inform me. OK.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The stand by lite flashing I have sound but no picture
Hello
Blinking of standby light in Sont TVs denotes fault indication. You just count the number of blinks occurs each time you switch on the TV. Please switch it ON and OFF by its front panel power switch, and not with the remote control. Do it three or more times, and keenly look at the number of blinks; confirm it, and send it to me through Fixya. OK.
Dec 02, 2010 | Sony KV-32XBR250 TV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Oct 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
