Question about GE Profile PSI23NCR Side by Side Refrigerator
No water to ice maker, but water to despenser.
  • Anonymous Mar 24, 2009
    Ice maker not producing ice but have water to dispenser
  • Anonymous Apr 20, 2009
    no water to the ice maker, but there is water to the door
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check water valve or ice maker or check for frost build up in freezer
Posted on Apr 07, 2009
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
Our ice maker stopped working but it still despenses water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
wryt
Sep 19, 2010 | Whirlpool GD5SHAX Side by Side...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
GE Profile PSI23NCR Side by Side Refrigerator Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
