Question about Wacom Intuos3 Graphic Tablet
I have the same problem and nothing helps! Its like the pen draws and moves and does **** all on its own and sometimes when i have the pen touching the pad the ERASER END SHOWS UP! Its like wtf... I hate how it works for like 20 mins then has the same problem over and over again. Unplugging it doesnt really work either nor moving a distance away. This thing is brand new and there is nothing in plain sight wrong with it... >_<
  • deadkiba May 06, 2009
    It goes everywhere! Ive wet it a few times on mistake. but its always worked fine until one day... long time not being wet dropped on it. both pencil and mouse goes everywhere and clicks everything! Specially on certain areas!
  • 4 Answers
Might be wet inside - you may want to try opening it up and giving it a good dry with a hairdryer between the circuit board and the top piece of the tablet which it's fixed to if any liquid came into contact with it. just be very careful opening it up, there's a little copper ribbon that's fragile connecting it to the bottom (on the USB cable side). The two pieces can't be pulled away from eachother
Posted on Mar 25, 2009
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
Pen Lag?
I had a serious lag issue with Genius Easypen F610E. You draw a square but the signal is laggy and it is unable to draw it properly. Leaves even a trace behind (see pic below with black squares). Searched the internet for solutions, it seems some others have the same issue.
Changing battery didnt help. Changing computer and OS didnt help. But its an issue of electrostatics (pen, tablet, your body) as I noticed. I needed to wrap a foil around the pen's upper part, and connect it to battery's minus terminal. That fixed the lag problem. Its not pretty, but it works.(see green squares in the picture).
It's seems to be a design flaw.
Jul 12, 2010 | Genius 31100006100 M609 G Pen
I have a wacom Intuos2. I have some proble with the pression of my pen. Suppose i draw something using the pen, it continues to draw even if the pen is not touching the tablette anymore. It happens with...
In the wacom control panel, there is a sensitivity setting. move the slider to less sensitive. this does not affect the pen pressure, only how sensitive the tablet is to recognizing the pens presence.
Mar 05, 2010 | Wacom Intuos2
Wacom CTE-440 Graphire4 tablet is drawing when I don't want it to
Ok so I called costumer service because mine was doing the same thing. Apparently the pressure sensor in the pen is stuck down. What you do is remove the pen tip with tweezers, blow in the open end of pen, then tap the pen (open end down) in a table to get any debris out of there. Then just put the tip back in and give it a try. That did the trick for me. Hope this helps.
Feb 23, 2010 | Computers & Internet
Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Dec 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Genius 8x6 tablet pen freezes
Try putting a new battery in it. Mine was having the same sort of problems, and they were pretty much entirely fixed by a new battery.
Apr 05, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Feb 06, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
My HP TX2050 pen works but the pen is not touching the screen.
you're probably resting your hand while you're writing...
this happend to me when i attempted to draw/write/what have you.
the computer can't differentiate between the pen tip and your hand, so what you need to do is disable your finger as a pointing device:
1) go to control panel
2) click on the mobile pc
3) go to pen and input devices
4) you should see a TOUCH tab. click on it.
5) uncheck the box that says "Use your finger as an input device."
This should help. obviously, you lose the capability to use your finger, and the whole idea of touchscreen in general, but you can always enable this after drawing or taking notes.
Hope this helps.
Jan 08, 2009 | HP Pavilion TX2000Z Notebook
Wacom bamboo problems in photoshop CS2
Yeahhh! Installing the new driver completely fixed my problem! Thanks guest!
May 09, 2008 | Computers & Internet
Pen writes in one spot, but image shows up 1/2 below.....
1. To calibrate the ENTouch 1000 power off the device.
2. Prior to restoring power touch the pen to the center of the screen and do not move it.
3. Power on the device. Leave pen in center of the screen and do not move it. If you move it the device will not enter calibration mode.
4. Allow device to boot. If you held the pen in place the EnTouch 1000 will enter calibration mode.
5. Follow the on screen instructions. Be very methodical and do not try to rush it...
Nov 20, 2007 | Ingenico eN-Touch 1000 Digital Pen
Wacom Intuos3 Graphic Tablet Logo
154 people viewed this question
Top Wacom Computers & Internet Experts
Level 1 Expert
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
