Question about Evenflo Comfort Touch Vanguard 5
Unable to remove cloth cover to wash
I can get most of it unattached but the two straps in the bottom
  • heather_m796 May 25, 2009
    i unscrewed the back bottom,back and the base to take out the bottom part of straps and now i cant figue out how to put the straps back thru now that there clean,,i'm so frustrated
    Problem Solver:
  • 5 Answers
Here's the official guide:
Posted on Jul 25, 2009
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I want to wash my covers to my maxi cosi car seat ive manged to take the cover off but im stuck on how to get the cover away from the straps
Found this solution on this website, and works great!
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Dec 06, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Clothes are hung in bottom and unable to remove catalst model
I recently was able to work on one of these. Pop the outer agitator cap off and remove the screws holding down the bottom plate then you can fish out the clothes. Don't try to remove the inner agitator unless you just have to and makes notes.
More here
Sep 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Instructions on how to instal a second hand safe-n-sound car seat
how do i put the straps back on through the cover
Oct 19, 2008 | Baby Gear
Maxi cosi car seat cabriofix
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Jan 08, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Evenflo Comfort Touch Vanguard 5 Logo
198 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
