FixYa.com
Tags:
BenQ FP72G+  17
Benq LCD monitor FP72G
By jessie25 - usenet poster
Hi everyone,
A friend of mine gave me this monitor he bought at a garage sale for next to
nothing.
yellow power light at turn on of power point
green light when turning on computer,
but no image on screen
slight flash of white if I turn on and off at power button
Anyone have any ideas as I have NEVER been inside one of these as yet.
Cheers and thanks
Tony..
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
ther have a 3 year warrenty and arent even 3 years old yet try to ring benq
and say youve lost the reciept they have a man date on the back as long as
its not 4 years old thell fix it
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Probably a failed backlight inverter - very common. When it is at the point
where it should be displaying an image, shine a strong light at a flat
angle, onto the screen. If you can see a dim image, then you have no
backlight. Could be the inverter board, could be one of the CCFLs loading up
the inverter and stopping it. Replacements might be found at
Arfa
Solution #3
Helpful (85)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Most likely shorted on or two transistors on inverter PCB due to bad solder
on transformers in inverter.
Rudolf
Solution #4
Helpful (85)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
yeah, i have seen a few of these wee beasies. Change all of the 1000
uF capacitors near the inverters, even if only one is bulging.
Also check:- the two drive transistors on each inverter, if one has
gone bad then it will stop the monitor in the way you describe.
regards, -A
Solution #5
Helpful (85)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
in Message id: <
NEC 1810 (P.O.S.)
Inverter is about as reliable as a Yugo.
Solution #6
Helpful (85)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Check the cap(s) in the power supply - I have an oldish Samsung 18" screen
where the only fault was the main (big) cap had died.
Can you Help with these Monitors problems?
Monitors
Samsung LCD Graphics Module...
Having recently purchased a LCD... Answer This...
Monitors
Can't get internet access!!
I have 2xPc's on a cable modem... Answer This...
Monitors
moniter
replaced power supply now... Answer This...
Monitors
Need info on Memory for HP...
Lost manual and need to know... Answer This...
BenQ FP72G+ (Silver, Black) 17" LCD Monitor
LCD monitor
The backlight never lights and... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
