Question about Symantec WinFax Pro 10.0 for PC
I cant put our fax number in upon installation
I cant seem to put our fax number in upon installation the window just closes
  • 143 Answers
My fax machine is blinking "printer error", i cant rec. any faxes....URGENT
A printer error has occurred. Open the printer
compartment cover, make sure the print cartridge is
installed correctly, and then close the cover.
Dec 15, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
How can i use my fax with magic jack.using lexmark X2350
This is the answer that I got from the FAQ page.
SOMETIMES.
We do not officially support using faxing with magicJack.
Please try the following steps to use magicJack with your fax (contact your fax manufacturer for details):
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
It seems that it depends upon the faxing unit that you use.
Mar 31, 2010 | Lexmark X2350 All-In-One InkJet Printer
Need to fax docs w/ a Dell 942 all-in-one print-fax-copy-scan.
To install and configure the Microsoft® Fax software:Click the Start button.
Click the Control Panel icon.
Double-click the Add or Remove Programs icon.
Click the Add/Remove Windows Components icon on the left side of the Add or Remove Programs window.
When the Windows Components Wizard window appears, click to place a check in the box next to the Fax Services listing.
Click the Next button.
When the Files Needed window appears, insert the Windows® XP CD into the CD-ROM drive.
From the Copy files from: drop-down button, select the drive-letter that represents your CD-ROM drive.
Click the OK button. to automatically open and close several installation windows.
When the Installation Complete window appears, click the Finish button.
Close the Add or Remove Programs window.
Click the Start button, point to All Programs, point to Accessories, point to Communications, and then point to Fax.
Click Fax Console.
When the Welcome to Fax Configuration window appears, click the Next button.
Enter any appropriate information in the fields provided.
Select your data/fax modem from the drop-down button located below the Please select the fax device listing.
Click the Manual answer button or Automatically answer after (specify number of rings) button.
Click to select the Enable Receive listing.
 Note:
  By selecting the Enable Receive check box, you can receive faxes. However, selecting this option may cause the computer modem to answer all incoming phone calls in which you may not receive voice mail.
Enter your TSID (Transmitting Subscriber Identification) information in the field provided.
Enter the CSID (Called Subscriber Identification) information in the field provided.
When the Routing Options screen appears, click to select the Print it on check box if you want each received fax to be automatically printed. If selected, use the drop-down menu to the right of this field to select the Dell AIO Printer to print the received fax. Your printer must be on and connected to your computer in order to automatically print faxes.
To create an archive copy of each fax, click to select the Store a copy in a folder check box.
Click the Browse button to select the desired archive location.
Click the Next button to display the Configuration Summary list.
Confirm your configuration settings are correct, and then click the Finish button.
You are now ready to send or receive faxes.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&dn=1091795
Nov 14, 2009 | Office Equipment & Supplies
WINFAX SETUP CLOSES WHEN PHONE NUMBER ENTRY IS BEING PERFORMED
Winfax Pro has been long discontinued software. It also will NOT run properly under Windows XP. That is the problem.
Aug 14, 2009 | Microsoft Windows XP Home Edition with...
Also i cant close a tab after opening it and cant open icons.
Sounds like you have a virus or the like.
Try this online scanner to see of it resolves your issues.
Avira sometimes has issues when there's a virus on your computer upon installation.
Jul 15, 2009 | Dell desktop and monitor- Inspiron 530...
Maxtor D740X-6L 40 GB drive won't start up.
Put your windows xp disc in the drive and boot up from it, run windows repair or failing that reinstall on the upgrade option to keep your files and programs.
If that fails, you will have to do a full instal.
May 29, 2009 | Maxtor Hard Drive
Cant recieve faxes or fax out
try a different line out of wall or have your phone provider check the line
Mar 17, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Need to fax forward panasonic uf 895
Store the number in a one-touch area. example 15
name it FORWARDFAX
set
stop
Press 74 set
54
set
choose VALID
set
press one-touch number 15
faxes are now forwarded.
To unforward
press 74
set
54
choose INVALID
set
stop
Dec 18, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Symantec WinFax Pro 10.0 for PC Logo
162 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
