Question about HP LaserJet 3380 All-In-One Printer
HP Laserjet 3380 line the length of the paper.
I get a line down the length of the paper when I use the paper feeder.
Can anyone help with this?  I dont get a line when I use the glass to make copies only when I use the paper feeder.
    Genius:
  • 2,120 Answers
Lift up the document feeder and clean the small scanner glass.
Posted on Mar 10, 2009
The laserjet 3380 is smudging down the center of the print. tried cleaning mode, tried new cartridge
Depending on the # of copies you have on it...you may need a maintenance kit....(fuser)
Try stopping the printer (open the cover) when the paper is not all the way out and see if the smudge just starts when it is in the hot section (fuser)...if so, only solution is a maintenance kit.
Nov 06, 2009 | HP LaserJet 3380 All-In-One Printer
Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Aug 04, 2009 | HP Office Equipment & Supplies
Paper gets stuck in ADF Feeder
it sounds like you could need an adf assembly replacement
Jul 30, 2009 | HP LaserJet 3380 All-In-One Printer
Paper stuck in adf of HP Laserjet 3380
Please follow the instructions for clearing the paper jam outlined in this article from the HP online support site. Here's another link with info on the manual feed in case you need it, and the home page for your printer in the event that a manual would help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2009 | HP LaserJet 3380 All-In-One Printer
I have an HP Laser Jet 3380 All in One and when I tryed to scan it tells me that is not PC set up and that is no paper in the feeder when it is Please advise
Be sure to install the drivers on your computer for your printer. Also, remove the paper, and re-seat it to confirm is it properly installed in the printer. Make sure there aren't any paper jams.
If these solutions do not work for you, please feel free to search HP.com support site for more information about your product.
Driver re-Installation Proceedure:
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
Jan 25, 2009 | HP LaserJet 3380 All-In-One Printer
Bad fuser Laserjet 3380
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
HP Laserjet 3380
If it is from the adf which is on the top then there is a small piece of paper stuck in the back. open the lid and you will find a plastic holder in the back. This helps the paper turn through the adf. Usally the paper is in there or this is out of positions which will cause this.
May 12, 2008 | HP LaserJet 3380 All-In-One Printer
Doc feeder problem with adf unit
first check the copy wheather it is working it or not after that if it is working then try to fax and also check the phone line
May 09, 2008 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3380 All-In-One Printer Logo
220 people viewed this question
Ben Johnson
