I have a mitsubishi vs5061. I have heard that there is a way to bypass the pip board. I need to do this because my big screen the picture rolls. I had it replaced a few years ago, but can't find parts anymore. I really hate to have to just send it to the dump it is still a nice tv.
  • 5 more comments
  • dbar1962 Mar 10, 2009
    What you suggested does not fix the problem. The picture in the picture is not stuck. The screen still rolls. Thanks anyway
    I believe you are incorrect. I have seen the solution posted once before but lost it before I could try it. Thanks anyway
    I believe you are incorrect. I have seen how to bypass the pip board before, but lost it before I could try it.
    Thanks for the help but it still did not show me how to bypass the pip board.
    Thanks for the help. Could you tell me where to pick up this repair kit and what do I ask for?
    Thanks for the help and I will try that. It sounds a bit over my head. The one I saw was much easier. It was sodering a wire between two points I believe, but it was a long time ago that I saw it
    I,m hoping it will work. I know the tv is old but I really hate to throw it out.
  • 19,396 Answers
There is no way to bypass the pip board , if the PIP chip is faulty, you need to replace it.
If you have a rolling picture is not PIP, PIP gives you either a dark shape on screen or sound but no picture.
Often a weak signal from receiver can give you rolling picture problem, generally rolling picture is associated with signal problems.
Posted on Mar 16, 2009
    Scholar:
  • 164 Answers
Hello There.
Below is an easy to follow PIP Mod diagram. Hope this helps.
Thanks.
Posted on Mar 11, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, You may not be able to bypass but you can try replacing the PIP board. But make sure the part number is same. You can find one at ebay (Item number: 190290926763 ).
Posted on Mar 10, 2009
    Sergeant:
    Novelist:
  • 277 Answers
You can try  the instructions given by other experts first and check out.are they working.and also you can try getting the pip  boards from  radio shack. or from best buy. or from near by tv reparing shop you can place an order. or you can check out  www.partstore.com
    Master:
  • 404 Answers
Ask the person who made you hear it to do it for you because I am 100% certain you cant.
    Sergeant:
  • 320 Answers
To fix the pip board this has to be done  Fix remove C7036 and CC7001 sufrace mount Caps and replace with Radio Shack axial Caps 4.7 Mfd 35 WVdc.
and to by pass do this  Remove the VP plug and solder a 4.7 mfd 35/50 volt electrolytic capacitor between pins 5 and 11 of the VP connector with the pos lead to pin 5. Solder a .01 cap between pins 7 and 9. .
please rate the session if helped. thanks.
  • 4,234 Answers
As you found out, the pip module is no longer available. The typical problem with these is that the surface mounted capacitors fail. If it has not been too long, the caps can be replaced and the pip module should once again work. This should not be too expensive a repair. There is a "repair kit" for this problem that costs about $15 or so that contains all of the typically defective parts.
Dan
  • ABRsvcs Mar 10, 2009
    I'm not sure if the direct link would work, so look for the kit here:
    matelectronics.com
    At the home page, select the product search button and search for: mits pip
    This will result in a mitsubishi repair kit. This is the kit that you want and costs $13.95
    Good luck.
    Dan
    I don't have the schematic available to me at the moment. I'll research this and if a direct bypass is possible, I'll post that too.
    Dan
  • 10,515 Answers
  • 3 more comments
  • taran_2005
    taran_2005 Mar 10, 2009
    Here is a trick to bypass that module to see if your problem lies in that module cause both horizontal and vertical circuits pass through that module. Do you have (2) 4.7uf @ 50 volt capacitors on hand. Take the PIP board out. Those numbers you gave were the PIP. And on the connector where the module plugs in Jump pins7 to 9 with 1 capacitor +lead in 7 -lead in 9 take the other capacitor and jump pins 5 to 11 + lead on 5. - negative lead on 11. Solder a small piece of wire so the leads dont touch as the pass each other. Just push the wires from the caps into the connector. No need to solder then try to power up your set. Let me know what happens.
  • taran_2005
    The modle clips in to plastic sockets. There is two sockets and they each have a plastic retaining lock. Just pry the little clip away from the clip and pull the module up. I will check on the availability of the module for you. You may want to try the bypass just to make sure you need the module radio shack has the capacitors for about 1.00 each.
  • taran_2005
    If you are satisfied with my solution, do change my rating as FIXYA.
    Thanks.
  • taran_2005
    Well,
    If you want to order repair kit
    it would be available on
    http://www.cablesnbulbs.com
    Thanks.
  • taran_2005
    Thats an expired link for them.
    The name of the repair kit is S-kit.
    Let me check if i can find a place to purchase.
  • 583 Answers
Sorry to say but there is no such facility to bypass.its a myth and trying to do that will damage it more.
    Sergeant:
  • 300 Answers
On the remote there is a button called pip just press that button and the pip will get off.
Mitsubishi CS-35301 has a rolling screen. Need to access service menu.
you need replace capacitors in vert.output circ. Not a service menu.
Jan 28, 2010 | Televison & Video
When i turn my mitsubishi tv on the picture jumps it a 1993 big screen.
it needs either the pip module bypassed because the pip board is no longer available, or vertical capacitors or connections, very common complaints.
Aug 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Scrolling picture on an old big screen
These models have been known to have faulty capacitors on the PIP module as a result thy loose vertical synvh and the picure will roll. The PIP module is no longer available. But if you would like I can post a way for you to bypass the module and if the modle is at fault your tv will work fine, but you wont have PIP anylonger
Feb 23, 2008 | Mitsubishi VS-60719 60" Rear Projection...
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Apr 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Sound no picture
You can buy a PIP circuit card on the internet(about $15.00) that can replace your current PIP card. It will bypass the PIP function which is most likely the problem. Instructions for instal come with new card. It's a relatvely easy task if you are in anyway technically capable. Worth the try. Rexman
Apr 05, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
