Question about Refrigerators
My Welbilt Refrigerator w1100 is too cold. The freezer is fine but the refrigerator is freezing everything too. I just moved in and there is no manual. I need help on where to adjust the dial. I can turn it off because I hear the compressor click off...but when I just barely turn it back on it starts freezing again.
  • Refrigerators Master
  • 3,361 Answers
Replace the temperature cold control.
That is the on/off control.
Posted on Mar 10, 2009
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Frs26h5asb5 refrigerator not cool freeze cold, replaced therostate
The plug on the dampener is not plugged in correct. Frigidaire changed the design but never changed the harness. You will need to split the harness and move one of the plugs to the other terminal.
Mar 25, 2013 | Frigidaire Refrigerators
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Refrigerators Logo
599 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
