Question about Kenmore 24032\24036 Top Load Washer
GE washer selection knob doesn't engage
When I pull the inner knob out, it just turns without engaging the inner piece to select a wash cycle.
  • 6,784 Answers
The knob it probably stripped. i would replace.
Posted on Mar 10, 2009
The control dial on my GE washer doesn't engage and let me dial a setting.
Is this washer new if so should be covered by warranty if not attempt to take top off the way that dials turning it looks like it aint making connection at back of fascia may have popped out at back of dial knob
Apr 01, 2013 | Washing Machines
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
May 18, 2011 | Maytag Washing Machines
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
The knob is not working. It just turns without starting the washer. I have to press down hard to get the knob to turn to the cycle I want. Is there a way to fix this? GE Top Loader WHDSR109J
This is a common failure. The teeth on the knob have worn off. If you pull the knob out you will see a small clip that can be pulled off this will release the knob. Usually both pieces of the knob need to be replaced. For diagrams and illustrations enter your model # at www.appliancehelponline.com
Jul 22, 2010 | GE WVSR1060A Top Load Washer
The dial to select wash cycle (GE top load washer) seems loose. It is difficult to turn, as if something is not engaging. Any suggestions?
The knob wears out and won't grab. It is easy enough to replace if you know the trick. Take pair of tweezers and remove the clip behind the knob, just push on the replacement knob and oil the timer then move the timer around several times to help the shaft turn easier.b8e8a25.jpg
May 02, 2010 | GE WBSR3140DW Top Load Washer
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Kenmore series 80 model 110
If you are talking about the Cycle Selection knob, turn the washer to an OFF position, or unplug. I can't remember if you need to pull the knob out or leave pushed in, but the knob will come off by turning it counter-clockwise. After unscrewing it and removing, the plastic dial under the center knob will simply pull off. I hope this helps you. If you need further assistance, please let me know.
Jan 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Jun 25, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
172 people viewed this question
Sal De
fordexpert
Robert Rankin
