Question about Silex Technology Silex SX-200 - Print server - Hi-Speed USB / parallel - EN, Fast EN, EtherTalk - 10Base-T, 100Base-T... (SX-200-0211) Print Server
Silex SX-2000WG - Cannot Configure
I am trying to configure my Silex SX-2000WG to work wirelessly with a fixed IP address. My PC doesn't have a wireless card, it is built in to the modem/router. I tried USB and Wired to setup.
Should the default gateway be the modem/router/wireless device?
I am using Vista
Thanks
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
Set up epson workforce 600 printer wifi via dlink dir615
Configure the IP address range your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Click OK
Oct 26, 2012 | Epson WorkForce 600 All-In-One InkJet...
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
I have a problem with my wireless network. it does not connect with win xp and win 7.what should i do?
If your configure it with IP address then you must also configure your Desktop and Laptop with specific IP address. Or try to check your DHCP configuration, it should be on an auto obtain if your ISP or Internet Service Provider didnt gave you Static IP Address.
Hope it helps.
Sep 09, 2011 | Acer TravelMate 4400 Notebook
I cannot connect to 192.168.0.1 to configure my wifi.
If wireless has not been configured yet then you will need to plug it in using a cat5 network cable to configure the wireless.
Mar 13, 2011 | D-Link DIR-300 Wireless Router
Linksys WGA54G ver.1 cannot find
Try to use the game adapter as your wireless adapter to test if it is still working. Connect the game adapter to your PC and then configure it manually. Assign a static IP address on your PC same range as your game adapter and then configure the wireless settings same as your router. the Default IP address of the game adapter is 192.168.1..250.
Jul 04, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
I can not print
I had a similar problem that was caused by my firewall. I was able to get it to print fine but could not get it to scan.
To test, try temporarily disabling your firewall. Bringing up SX Virtual Link then search for devices. If you can find your Canon, that's the key. Silex has instructions on how to get around some of the firewalls on their web site. I had to figure out how to get around AVGs firewall on my own. Check out silexamerica.com.
Reply to this message if it doesn't work or if you need instructions for the firewall problem.
Good luck helena!
- Susan
May 03, 2009 | Canon Silex Pricom C-6200U (0297V462)...
Trying to switch routers, can't get into new Netgear to configure
To configure it you can simply contect a pc to one of its rj45 port. it will give the pc an ip address in a default range. but the must have its network connection configured to receive ip automatically.
See the status of the pc LAN connection and note the gateway ip address. then type this ip in your explore address bar to access the configuration page / program of the router.
Hope that help.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
Silex sx-200 print servers loosing its wireless signal
I work with Silex and can send you the latest firmware release candidate for the SX-200 that includes changes that improves the performance of the unit's wireless radio. Please email me at fponio@silexamerica.com with your full contact information with reference to this post and I can reply with the updated version file and instructions on how to load this file on your unit.
Thank you.
Francis Ponio
Technical Support
Silex Technology America
Dec 19, 2008 | Silex Technology Silex SX-200 - Print...
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Silex Technology Silex SX-200 - Print server - Hi-Speed USB / parallel - EN, Fast EN, EtherTalk - 10Base-T, 100Base-T... (SX-200-0211) Print Server Logo
202 people viewed this question
Top Silex Technology Computers & Internet Experts
David Payne
David Payne
Are you a Silex Technology Computer and Internet Expert? Answer questions, earn points and help others
