Question about Brother XR7700
Upper thread won't pull up lower thread
My machine jammed after I ran out of upper thread without noticing. I cleared the jam, re-thread the machine and now the upper thread won't pick the lower thread. It looks like the upper thread isn't even going down there!
  • haleysd83 Mar 11, 2009
    Tried that but all that happened was the needle kept hitting something? ahh
    Sergeant:
    Champion:
  • 239 Answers
Adjust needle lower it down
Posted on Mar 10, 2009
When i thread itdown aroundand back up to thread take up it gets tight before i thread the needle
check that you have the thread between the two plates that form part of the upper thread tensioner
when threading it is very possible to have the thread go behind a plate and get jammed on the adjuster thread
other than that loosen of the thread adjuster a bit
Jul 21, 2015 | Sewing Machines
Upper thread on embroidery machine jamming machine, and ending up with a bird's nest in the bobbin area.
Upper threading is wrong. Thread could be catching on the end of the spool. What machine are you using?
Apr 28, 2015 | Sewing Machines
Remove thread jammed in bobbin case holder
Just open carefully the front of the machine (attention where everything has to be put back), identify the problem and try to remove the thread. Inspect the inside of the machine and the lower bobbin case for thread that may be tangled . Take it easy and you will fix it ; most of the times you we'll not need professional help. Post back to tell us where the problem was and how you fixed it.
Sep 29, 2014 | PfaFF Creative 7570
Thread setting out of wack; bobbin thread won's connect with "too loose" top thread
Your tension adjuster is either set incorrectly or needs repair. Bobbins also have a tension setting, though it is not often necessary to adjust them. If they do, it's usually done by turning a tiny screw a very tiny amount. Best to mark the original location of the screw so you can reset it if need be.
Clean out all the thread, clean the bobbin case area thoroughly, a soft brush is good for this, as lint buildup can cause jamming. Set the upper tension around 3 or 4, and try turning the hand wheel slowly to see if the upper thread picks up the bobbin thread properly. If not, adjust the tension again. If you cannot get it to make a nice even stitch, the tension adjusting mechanism may be in need of repair.
Jul 16, 2014 | Singer 6423 Sewing Machine
New to me. Threaded machine- started with needle in material. Stitched a couple of stitches and all the lights went on and buzzer went off.
Maybe, pull the material out of machine, and make sure that the thread didn't all jam in the bobbin area. If so, clean it out and rethread your machine, upper and lower. Now, put the material in again, but do not start with needle in the materal, make sure that it is in the highest position. Hang on to your threads, upper & lower, for a few stitches. If, your material is real stretchy or thin, put some stabilizer under it, or gift wrapping tissue paper under it. See what happens now. Good luck
Nov 17, 2010 | Singer 7422
Jamming or timing at bobbin
The bobbin case should be loose enough to wiggle a little. Take it out and look for needle strikes or damage on the edges, if it is damaged you can try to smooth it up with fine file as a temporary fix but purchase a new one soon as possible. The other two factors to look at is the upper thread take up lever, make sure the thread is in it and then check the upper tension by pulling thread thru the needle. When the presser foot is in the raised position, the thread should pull thru the needle easily, when the foot is lowered onto the fabric, the thread should be hard to pull. If it is still easy with the foot down then the thread did not go into the tension discs properly or the upper thread tension dial is set at too low a number. It should be on a 3-4 or 5kif I remember correctly.
May 27, 2010 | Janome 6260QC Computerized Sewing Machine
Upper thread winding around shuttle hook of sewing machine
rethread the needle as the thread has no tension
Aug 30, 2017 | Euro-Pro Sewing Machines
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Lower thread keeps jamming in bobbin compartment - urrgggg
Take the bobbin carriage out and clean it really good. Use the little brush that comes with your machine and brush everything. When m y machine jams up like that it usually means there is lint or thread caught in the bobbin carriage.
Jan 01, 2009 | Bernina Sewing Machines
Brother XR7700 Logo
510 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
