Question about Dell Inspiron 600M Notebook
Inspiron 600m,"no input signal check video cable"?
My laptop has been working excelent in the docking station until recently, all I can get it the message " no input signal, check video cable" and I have searching on the net for a few days with no luck, I had opened the key cover and blow out the visible dust, clean the conector in the back of the laptop. any surgession would be appreciated. I am certain that the dock station and the others monitors are working fine, I have video if I use VGA cable to expand to the second monitor
  • christoph610 Mar 11, 2009
    I laptop screen function nornal, and the external monitor function normal. When pressing Fn and F8 I can can cycle between monitor and LCD. My question is what can I do to make the monitor screen to show image of my desktop when I boot it up by pressing the power button ( it used to be that simple). Is there any set up in the msconfig , I should look out for?
  • 4 Answers
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Posted on Mar 11, 2009
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
I have a dell inspiron (600m) andi also have a dell flat screen television. i used to be able to connect my laptop and tv, so the tv would become a flatscreen. i would go to VGA and my laptop would appear....
I assume you would switch the TV's source to VGA. Is that correct?
Connect it the same way you did before, with the VGA cable. Then hit Fn + F8 on your keyboard, to switch the signal from your laptop screen to the VGA cable. Then select VGA as your source on your TV as you did before.
If that does not work, please post and tell us what type of television you have.
Mar 29, 2010 | Dell Inspiron 600M Notebook
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
Unable to connect my pc to TV
The reason why your TV is showing no input from your laptop is because of the display resolution of your graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs can handle.
I have actually dealt with a no input signal like this before, and this was what I did.
Hope this helps.
Jul 18, 2009 | Dell INSPIRON 600M HARD DRIVE CADDY 6X609...
Not charging off the power jack
One wrong spark and you'll need a new laptop. Take it to a reputable repair person. A jack is an repair.
Mar 29, 2009 | Dell Inspiron 600M Notebook
Laptop won't dock
The inspiron 600M will not function in a D-Dock, but will work in a D-Series port Replicator. (Although the D600 and 600M share the same motherboard, the bottom plastics are different)
After trying the 600M in the D-Dock, it is possible the dock is damaged. I would undock the D630, then delete the docked profile. power off, dock, and reboot and see if it detects and works.
Jan 16, 2009 | Dell Latitude ATG D630 Laptop
Denon ASD-3w ipod dock not being recognized by denon 3808
I successfully connected the ASD-3W to the Denon 3808CI using the supplied AV/Control cables (dock control, L & R audio, S-video). I used the video and audio input connectors marked VCR (iPod) on the 3808CI and used the default settings. I used the connector marked Dock Control for the control cable. These VCR (iPod) connectors are different than the input connectors marked VCR. I turned the source selector to VCR/iPod Stereo and operated the GUI using the ASD-3W remote control. I was able to play music and video.
Nov 16, 2008 | Denon ASD3W IPod Networking Dock Docking...
Tv to laptop
disable your laptop screen try that jules
Apr 26, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Connecting iPod Docking Station to Video 4
On your iPod, go to Videos, Settings, and set it to TV out. Make sure the TV Signal is set to NSTC.
Jan 19, 2008 | Onkyo TX-DS787 Receiver
Dell Inspiron 600M Notebook Logo
467 people viewed this question
Alun Cox
