Tried to update to DVDFab 5 and when my computer went to reboot, I get the Microsoft Corporation loading screen, and it won't get past there... (I let it "load" for about half an hour)
  • 2 more comments
  • staticmissi Mar 11, 2009
    Windows doesn't load. =(
    I have Vista 32 bit version, if that helps any. I am searching for a solution on someone elses computer.
    What point in time would I tap F8? While the screen is still black or during the Microsoft Corporation page, or does that only work when windows will actually load?
    Thank you for your quick reply!
    the manufacturer logo never appears come to think of it... I will try the F8 when I get home though. Thanks
  • Robert Miller II May 11, 2010
    basically start tapping it after your manufacturer's logo disappears and before the windows loading screen appears.
    Have you tried right before windows loads, tapping the key and selecting Last Known Good Configuration?
    Problem Solver:
  • 13 Answers
Restart the pc and keep Pressing the "F8" key while it is booting. You will get a menu , select "safe mode" from there and you will be able to boot the pc into safemode. Next It will take u to the desktop and ask if you want to restore your system to previous date, Click on "Yes". Next click on the date on which you upgraded dvdfab and click on next. Your pc will be again fine after restoration is complete and rebooted. Thanks
Posted on Mar 17, 2009
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
My HP laptop tries to start up but freezes on the "microsoft Corporation" screen with the green loading bar. I tried to do a System restore, but it wont acknowledge any recent restore points at...
Freezing at the "Microsoft Corporation" screen is normally caused by Windows updates. Since System Restore did not work for you, you can also try to disable unimportant services and start-up items. Usually this kind of problem ends up to reinstalling the operating system.
But you are lucky if reinstalling the operating system would fix the issue. Sometimes you'll end up wondering what to do because you'll end up with the same screen after the computer reboots itself from the long process.
With this kind of issue, I suggest you to try to run a hard drive diagnostic tool or try to use a good known harddrive.
Hope this helps.
Jun 03, 2011 | HP Pavilion dv6000t Notebook
I GET A MESSAGE STATUS CODE 22FB-3080-B200-0700-C000-0013
Holding the sync button on the console as per other forums didnt work initially, so did it loads of times:
Had the disc loaded that caused problem, held sync button on the console and powered off and on still holding the button on. Powered off each time the error screen came back up while all the time holding the sync button on the sixth attempt it went past error screen and up to dashboard.
I went to load disc again and it asked me for update again so chanced it, this time it extracted update ok and then rebooted to dashboard ok.
Console now running fine, oh and Assassins Creed was the game that caused the initial update error, and Assassins Creed was the disc that I used in the multiple reboots which eventually cleared update fault.
Hope this helps as no other info on web that I could find.
Feb 05, 2011 | Microsoft Xbox 360 Console
Acer 5920 has done start up repair but won't reboot from microsoft corporation screen
Have you tried System Restore? Sometimes if startup repair wont fix the problem on booting to windows, system restore can. Just remember to select the date where the computer is working fine.
Dec 14, 2009 | Acer Aspire 5920-6727 Notebook
6t04 code 31
To solve this problem with 6To4 adapter device with code 31, make sure you do the following:
1). Make sure you have all the updates installed for vista, such as, Important and Recommend updates.
2). [Right Click] my computer icon, and select (properties).
3). Select (Device Manager).
4). [Right Click] on the 6To4 icon, and select (Update Driver Software).
5). Click [Browse my computer for software drivers].
6). Click [Let me pick from a list of device drivers on my computer].
You should see the Microsoft 6To4 adapter listed?
If not you must uncheck the [] box show compatible hardware.
7). Then scroll down the list of Manufacture until you find (Microsoft), NOT Microsoft Corporation!
8). Click on (Microsoft) as the Manufacture and scroll down about two clicks, you should see 6To4 adapter.
9). [Left Click] on Microsoft 6To4 adapter and (Click Next), it should load the drivers as normally.
Dec 04, 2009 | Dell Inspiron 1545 Notebook
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Configuring updates dont stop
I'll assume last known good configuration didn't work, if you press f8 and choose disable automatic restart on failure, you should see the blue screen of death with more info, when you reboot the next time,(you may have to hold in power button for 5 secs), press f8 and see if Repair my computer is listed on the Microsoft Startup menu, if not, insert a windows vista disk and restart,booting to the cd(should happen automatically, but look for a prompt to press a key) choose your language, then choose repair my computer, choose the windows installation, and you can try to use system restore to go back before the uodates were installed and updated, then disable automatic updating so it doesn't repeat.
Mar 26, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
