Question about Linksys WRT160N Wireless Router
Cant get my router to for my laptop
My router works for my desktop not for my laptop i have vista for my laptop when i try to add another computer it wont let me it say internet connection
  • 1 more comment
  • trish3270 Mar 11, 2009
    wrt160n
  • trish3270 Mar 14, 2009
    well i did what you told and it does not work
  • lord_loki
    lord_loki May 11, 2010
    What router is it?
    Problem Solver:
  • 10 Answers
Make sure you have wireless enabled on your router and on the laptop. For the router, on your desktop open a web browser. Type in 192.168.1.1 in the address bar. The default user name is blank and the password is admin. This will log you into your router. Once logged on, click on the wireless tab. Make sure that wireless is enabled and you have an SSID (also known as a Network ID). Also, make sure SSID broadcast is enabled. When this info is verified and set up you can close the web browser.
Now move to the laptop. Click once on the network icon on the taskbar (the 2 computer monitors by the clock). Select "Connect or disconnect..." When the window comes up, select your wireless connection.
Posted on Mar 12, 2009
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
Cant get my vista labtop to print through router
Did you share the printer PSC 1410 in the XP Desktop computer??
Thanks
Riz
Jan 14, 2009 | HP PSC 1410v All-in-One Printer
Wireless connectivity
You probably set an access list on your router
connect to Router using a LAN cable and check if you can browse.
Then
Check your access list on router.
Disable it if you cannot add your PC wireless adapter MAC address
Jan 04, 2009 | Computers & Internet
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
I cant get my internet on me vista laptop to work. i have two wire computers and one wireless and the second wire computer makes the laptops internet shut down and when the laptops internet works the wire...
Ok here is the big question what make and model is your router. Anything less than an "n" class router is going to gang up on itself. Also depending on your internet service provider or "isp" and the speed that they provide makes a difference. I find that it is the lower grade g-class routers that have the most trouble. Take care...Be mucho blessed...Mark
Jun 28, 2008 | Computers & Internet
Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
Jan 07, 2008 | Belkin (F5D5231-4) Router
Linksys WRT160N Wireless Router  Logo
114 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
