Question about Kenmore Kitchen Ranges
Oven panel shows code F1
Oven timer was on when the code F1 came on
  • elwood61855 Mar 10, 2009
    model # 79046812992
  • steve
    steve May 11, 2010
    Must have the 11 digit model number to assess.
  • Kenmore Master
  • 3,361 Answers
Your electronic control is defective and must be replaced.
Sorry.
Posted on Mar 10, 2009
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: Oven shows error on control panel: F1:E9.
Replace the electronic range control ERC
Posted on Nov 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Error Code F1 on oven timer panel
These ovens have a internal reset feature on them that resets the control memory program
So if you disconnect the power to the oven for at least 1 hr this will also reset the memory program this is very helpful if your door has been locked because of the cleaning program being interupted and the door will not open ok?
Posted on Dec 18, 2011
Fix error code E1-F1 on kenmore oven...model-95802000
That us usually a fatal error of the control board unfortunately. the control may need replacing.
Sep 17, 2014 | Kenmore Kitchen Ranges
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
After a storm my Kenmore oven keeps blinking the F1 light and the timer goes off every 20 seconds How do I reset it
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Display panel on stove not working properly, cannot use the oven
&^%$tr
Jan 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Code F1 on my range my oven will not turn on.
Feb 12, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I have the same problem as above. Is there any quicker way to get an answer from tech support. I have no stove or oven right now.
Sep 05, 2008 | Kenmore 46123 Stainless Steel Electric...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
