Question about HP DeskJet 920c InkJet Printer
I am trying to connect a hP5740 printer to my laptop with Vista and via USB. Laptop does not recognize printer and will not print.
  • frances965 Mar 10, 2009
    Printer will not print.
  • Mr fix.it May 11, 2010
    does the computer detect that you connected a device or it does nothing as if nothing was connected ?
  • 3 Answers
Have you installed the drivers for the printer?
Here is a driver for the printer
http://www.techspot.com/drivers/driver/file/information/7347/hp-deskjet-5740-5743-5745-5748-10400-/
Posted on Mar 10, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Connected Canon MP610 to Apple Time capsule via USB. My Macbook pro prints wirelessly perfectly, as does my sons Vista Laptop, however my daughters vista laptop and my wifes XP laptop print black fine, but...
Hi richardhaley,
Isee that you are having issues with your Canon MP610 printer.
You mentioned that your printer is connected to an Apple Time capsule via USB and that it works fin on your Macbook and on your sons Vista Laptop but prints the colored shifted to the right on your daughter's Vista and wife's XP Laptop and this is connected via USB.
If I may ask have you tried printing wireless using your daughters Vista Laptop and you wife's XP Laptop to see if the colors are still gonna shifted to the right.
Also you mentioned the drive that the driver you are using is from bonjour but still you have the same problem.
Here is a link where you can download drivers specific for the versions of windows your daughter's Vista and your wife's XP would have, you will need to select exactly the OS operating system for the driver that you need also there is a software for each Operating system as well maybe you can download that as well for both system for you to be able to recalibrate the printer from the 2 machines.
I hope that this will help.
Thank you for choosing Fixya,
mvincentc
Jun 06, 2011 | Canon MP610 Photo All-In-One Printer
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Vista laptop recognizes HP printer but won't print
Make sure the usb cable between the laptop and printer hasn't come loose. That's usually what happens when when the cable isn't sitting in the slot properly
Sep 22, 2009 | Toshiba Satellite A355-S6925 Notebook
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Only prints on computer restart!
Have you tried a different port?
This will identify if it is a USB issue, possible USB 1 or 2.
It sounds like an issue with your port and not the printer, do you have access to advanced settings on your computer for USB?
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
HP DeskJet 920c InkJet Printer Logo
110 people viewed this question
Ben Johnson
