Question about Uniden Radio Communications
Replacement arial for uniden UH045XR needed - Uniden Radio Communications
    Problem Solver:
  • 18 Answers
It uses a standard scanner antenna I also have the original manual in pdf if you need it. You can get a replacement at radioshack or
Posted on Mar 12, 2009
<p><font face="arial,helvetica,sans-serif"><span style="font-family: Arial;"><b>
Diagnosing Panasonic microwave oven stoppages:</b><br>
If it stops after 22 seconds, that means the controller has detected a problem,
usually a problem with the inverter, controller,&nbsp;magnetron, or a bad connection
from one or the other.</span></font><br>
<font face="arial,helvetica,sans-serif"><span style="font-family: Arial;"><br>
If it stops at 16 seconds and is a sensor model, it probably has a defective
humidity sensor.<br>
If it stops after 7 seconds, it has a problem with the&nbsp;inverter.</span></font><br>
If the digital programmer circuit / controller does not get a feedback signal
from the inverter for a period of 3 seconds, the controller will stop the cook
Or see if this describes what's happening:<br>
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes
off. Cook time on display goes off and clock time comes back. Bad upper
interlock switch and charred connector. If so, see:<br>
<a href=""></a></span></font></p>
<a href=""></a><br>
It may be a loose connection in the wiring between the inverter,&nbsp;magnetron,
and/or control board, or maybe one of those components has failed.</span><br style="font-family: Arial;">
<font face="Arial"><br>
</font><span style="font-family: Arial;">Due to the complexity and lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.</span><br style="font-family: Arial;">
<span style="font-family: Arial;">You can </span>
<a style="font-family: Arial;" target="_blank" href="">
find an authorized Panasonic servicer here</a><span style="font-family: Arial;">.</span><br style="font-family: Arial;">
</font><span style="font-family: Arial;">In Canada, you can </span>
find an authorized Panasonic servicer here</a><span style="font-family: Arial;">.</span><font face="Arial"><br>
Oct 17, 2013 | Panasonic Microwave Ovens
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
Uniden bc340crs scanner just static and will not run thru channels
An unfiltered power supply my give that problem or you need an external arial
Jun 09, 2011 | Uniden BC340CRS Base Scanner
How do I change the outgoing message. I Have Omega 2080
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Arial; color: #1a1a18} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 9.0px Arial; color: #1a1a18} span.Apple-tab-span {white-space:pre}
1) On the phone base, press and hold "greet"
2) The phone will say "record greeting"
3) WHen you finish recording your greeting, press "greet" again or the Play/Stop button (A triangle and a square)
The phone should now play back your greeting.
You can download the entire product manual here:
Mar 07, 2011 | Uniden Cordless Phone
Teac CR H250 plug into arial
The only thing that would damage DAB reciever is lightning hitting the arial. But all you have to do is unplug during a storm. You might get a better reception with the £100 job, but I think he was a conman!
If in doubt read the instructions!
Jan 29, 2010 | Audio Players & Recorders
How do u change electric arials on a pajero i have been told i only need to replace arial mast not the whole motor
If the mast is broken then you can unscrew the top part of the aerial, turn on the radio and pull till the whole mast and perlon come out, then get your new mast and feed it into the aerial and turn the radio off, this should pull the mast and perlon in. other wise buy a new arial, you will need to get under the wheel arch and remove the plastic cover, the aerial will be held up with a screw.
Dec 27, 2009 | Car Audio & Video
Radio Communications Logo
90 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
