Question about Ford Tractor 8n Front Emblem
Power going in to dist. no power coming out - Ford Tractor 8n Front Emblem
  • 218 Answers
Hi..my name is Keith..and you didnt give me very much information about what kind of machine.tractor you have..but there will not be any power comming out of your distributer if the points are up on the cam and the points are open..but if the points are on the flat side of the cam..there should be voltage..if the points are on the flat ..and the points have no voltage the the points are either burnt or have arced and pitted and that means that the points and condensor needs replacing..i hope this has helped..if not with me back with further details and i will be glad to help you
Posted on Jun 30, 2009
I have no power going to dist.
You didn't say what year, make and model. Power to the distributer come from the ignition switch. Diagnostics is a fuse.
Sep 14, 2014 | Cars & Trucks
Where does power come from for dist
large wire cliped into dist.cap, powered from ignition swicth
Dec 24, 2013 | 1985 Buick Skylark
Honda civic eg8 ,no spark in distrubitor
so the wires from the dist. cap to the plugs are ran wrong? best way to get it right is to lay them out shortest to longest and go from there. Or is it an electronic dist. and its powered and ran from the wiring harness and ecu? because in that case, if you put in an aftermarket piece, you may need to flash over the ecu or get a piggy back so it and the dist. can talk to each other. hope that helps some.
Apr 20, 2013 | 1995 Honda Civic
Power to new dist no spark
You need to run a fault code test on the electronic engine control ystem, to do that go here.
Oct 10, 2012 | Cars & Trucks
1997 chevrolet blazer does not have spark in the spark plugs I already replaced the crankshaft sensor and still wont start
if it has a distributor, it is most likely the ignition module inside thats shot. call an auto parts store. and I think they can test them to be sure if its bad or not. check the cap and rotor also ! you can turn dist. a bit if timing is off. theres a hold down bolt underneath dist just loosen it. just so you can turn it to where it runs the best! then tighten and try it. if not the module. make sure power is going to dist. also make sure dist. shaft is turning, in dist. hope this helps.
Aug 31, 2011 | 1997 Chevrolet Blazer
Code 11 1985 dodge 600 turbo does the dist. signal
Quite often "hall effect pick-up" in distributor is problem . Remove distributor cap and rotor and you'll see the round plate with wire harness/plug to it. motor1258_29.jpg
Aug 05, 2011 | 1985 Dodge 600
There is no power going to the dist cap. I put a new coil in but this did not fix it. The spark plugs will not fire. Everything works but the plugs will not fire. The engine just turns. Ichecked the wires...
U have a power wire that has been breached ur gonna have to check continuity to ur power wire at the coil and dist hook one lead to the fuse that supplies power and other lead to to same circuit under hood at coil repeat step with all wires on coil and dist just to be sure.
Apr 03, 2009 | 1992 Plymouth Voyager
Ford Tractor 8n Front Emblem Logo
96 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
