Question about Microsoft Xbox 360 Console
My 360 hard drive erased itself. All my saved information is gone from the system, however the HD still shows 9gb of space being used. First can I recover my info and if not up to I free up the space that is being used by ''nothing''
  • Dorian Davis Nov 28, 2011
    i had the same problem the other day, did you ever figure it out?
    Problem Solver:
  • 19 Answers
Someone probibly hacked it cause that happened to my one friend. contact microsoft.
Posted on Mar 13, 2009
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
How do you erase hard drive
Hope this helps.
Dec 20, 2012 | Computers & Internet
Seagate 500 GB external hd that suddenly changed from NtFS to RAW
You can use a utilities like partition recovery to try to recover the previous partition.
Sep 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Jun 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My drc8030n says I am out of space
To format the HD in the DRC8030N, do the following. Power off the unit (so you only get the clock on the LCD) and then press and hold the PLAY and OPEN/CLOSE buttons for about 5-6 seconds or until you get the FORMATING word in the LCD. It will do this for about 5 seconds and voila, you are back in business. Keep in mind that by doing the following you will loose all your saved info like saved titles and such. So if you have a saved TV show that you really do not want to erase, then record it to a DVD Disk first. I hope this helps
Jan 11, 2009 | RCA DRC8030N
Saying I can't copy 9gb file due to lack of free space, 433bg still showing free
that might be due to the drive being formatted as Fat32 which has a file size limitation of 4 Gig..open up my computer, and look at the properties of that drive..right click..and that might help you
Oct 15, 2008 | Western Digital 500GB My Book World...
Not enough space to use Acer Backup Utility (Aspire 3000)
Cick browse after you have chosen to save and your external drive should show up on the pop up menu.The image you are trying to save may be of a format that is not recognizable by your external drive.Or you may have to choose which format you want to save it as from the source.
Aug 10, 2008 | Acer Aspire 3000 Notebook
175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Free Space problem
Running at that low of free space is a bad thing to begin with. You didn't specify if it's your primary drive, internal or external, or anythign, but I'm going to assume it's the one with Windows/Operating system on it.
Most modern operating systems need a few hundred megabytes, if not more, as "swap" or "temp" space. When your drive drops down to the levels you seem to be at you can get problems liek that which you mentioned, due to free space allocation for temp files, and whatnot.
Without more detail, like which operating system, type of HD, HD use, type of file you're saving and total space on the HD, I am afraid I can't help more.
For now I suggest deleting some old files, emptying your trash can/recycle bin, or simply restarting (if you don't do that much) to clear the cache.
Mar 17, 2008 | Kingston (SDCZ2-512-A10-KT)...
Microsoft Xbox 360 Console Logo
327 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
