Question about ValuSoft Print Workshop 2009 for PC
HOW do you setup this DVD
Just bot Print Workshop 2009 and it does not seem to work on my computer...I have XP and did the run D:SETUP.EXE. and nothing happens. What should I be doing.Thanks,Lynda
  • jpaul1216 May 11, 2010
    Are you getting any error messages?
You can do the following:
(1) Go to Start, Run, then type in D:\Setup.exe (D is whatever your DVD-Rom drive in). --->Follow the on-screen instructions.
(2) Go to my computer, right-click on the DVD-ROM, and choose the Autoplay or Run option.
(3) Right-click on the DVD, click on explore, and click on Setup option.
Also, make sure that your computer can accept DVDs.
Posted on Jun 30, 2009
How do I install print shop 3.5 on Vista Home?
Insert the disc into the DVD drive in your computer. The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe. Note: If the installation does not begin automatically follow these steps: Click on Start. Click on My Computer (Computer on Windows Vista and Windows 7) Right Click on the DVD drive containing The Print Shop 3.5 disc. Left Click on Open. Double Left Click on Setup.exe. The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5. If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically. From here you should follow the on screen prompts to complete the installation.
Feb 12, 2015 | Encore The Print Shop 3. 0 Deluxe for...
Question ashbassili asked on Office 2007 setup.exe can't find setup controller file - either network error, error reading DVD or problem with the package. This is a fresh install off a DVD. Onto a
Sounds like it's a compatability issue. Try right clicking the .exe setup file and choosing run in compatability mode. Or you could try right clicking the .exe setup file and going into property's, run in, and choose run this file in Windows xp service pack 2 mode. Apply the changes and try again. If that still won't work make sure your PC is fully upto date and has all net framework packages installed. A lot of programs refuse to install unless you have all the necessary updates and frameworks and Java installed. It doesn't specifically tell you the problem. Just gives you an error on install.
Apr 26, 2017 | Microsoft Office PowerPoint 2007 Upgrade:...
Reader rabbit software won't install
If you are attempting to install this under Windows Vista or Windows 7, it may be a compatibility issue. Open computer and right click on the cd/dvd drive and click 'explore'. Then look for 'Setup' or 'Setup.exe' and right click on it and click properties. Go to the compatibility tab and check the box next to 'Run this program in compatibility for' and select either Windows XP (any service pack) or Windows 98 if that does not work. Also check the box next to 'Run this program as administrator' and click 'OK' at the bottom. Now you should be able to run Setup.exe and install the program.
Mar 05, 2011 | The Learning Company Reader Rabbit Reading...
I need help to install this program
Hello Cryspycritte, Thank you for the clarification. Your program is definitely compatible with Windows XP. What you will need to do is put Disc 1 of Print Workshop into your CD drive. Click on your start button in the lower left hand corner of your desktop, then click run (located right above the "turn off computer" button.) A run box will appear in the bottom left hand corner. In the box type: D:\setup.exe (where D is the letter of your cdrom.) A setup window will appear with the final steps for installation. If you have any installation issues please post a reply. Thanks for using FixYa! Edward
Aug 24, 2010 | ValuSoft Print Workshop 2003 for PC
I cant seem to get the set up working to install Warlords Battlecry 2 on windows vista
Try copying the contents of the cd to the desktop then rightclick the setup and run as administrator.
You could also set the setup to XP in compatibility mode
Jul 18, 2010 | Red Orb Warlords Battlecry 2
When i try it says setup.exe has encountered a problem and needs to close
try right clicking to it and run as an administrator. the file maybe corrupted thus making it unable to work. If it is not working the setup.exe file must be corrupted. Try downloading a new copy or buying the original copy.
Aug 10, 2009 | Panda Antivirus Pro 2009 - 3 User for PC
Cant seem to load my footie manger 09?put disc in but cant find how to load the game
Run the setup.exe, install.exe or setup.msi program on the CD drive in which you placed the CD.
Ex:
D:\setup.exe
Mar 06, 2009 | Microsoft Windows XP Professional With...
DVD/Cd Burner won't run programs.
All you need to do is that put the CD in the CD/DVD drive that you have access and not properly closed. For example here is the situation. I put a cd installer with a file named in the cd setup.exe and it is located in drive D: i access the file setup.exe and I run it or install.. then I decided not to install the programs.. what I did is that is did not cancel the installation but rather I immediately open my cd/dvd drive and get the cd..
What are going to happen? the installation is in the process and I did not cancel the installation properly. In the installation logs of the windows it still have to install the programs but it cannot find the file setup.exe that is located in the Drive D:.
Try to put a cd in your cd/dvd drive with file named setupexe on the cd.. that will solve your problems. TY
HOPE I CAN HELP
Dec 05, 2008 | Acer Aspireā„¢ T180 PC Desktop
I HAVE A IBM PC CAMERA AND NO SOFTWARE TO INSTALL ON MY COMPUTER WHERE WOULD I FIND WHAT I NEED TO DOWNLOAD
Try this:
http://www.geekstogo.com/downloads/ibmv5000w2kxp.exe
  • The IBM 33L4889 PC Camera Windows 2000/XP Driver installation exe will show the following message: Thank you for downloading the IBM PC/Net Camera Software Driver for Windows 2000/XP. Make sure the IBM PC/Net Camera is unplugged from the computer before installing this software .
  • Click [YES] to continue, the exe will then extract setup files to c:\\setup folder.
  • Go to C:\\setup folder, you will find Setup.exe there, double-click to run it.
  • Follow on-screen instruction to finish the setup.
After installing the IBM 33L4489 PC camera driver, you will have two exe, namely IBM PC Camera.exe and Vidcap32.exe. You can use IBM PC Camera.exe to take snapshot, make V-Mail as well as capture images.
Or you can try here:
http://rapidshare.com/files/138223777/33l4889.zip
Don't forget to rate this a Fixya if it helps!
Thank you and good luck.
Nov 11, 2008 | A4tech Xmaster PK-835 Webcam
I just bought the Print Workshop 2009 and I put it in my computer and nothing happens. I also click run and typed in d:\setup.exe and it tells my it cannot find it
I bught the same thing and it is on dvd so I had to buy a dvd for my computer and then it works but I don't know how to use it. I bought the dvd/cd from wal-mart on sale for $29.00 and installed it myself, works like a charm
Jul 01, 2008 | Televison & Video
ValuSoft Print Workshop 2009 for PC Logo
121 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
k24674
Edwin
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
