Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Cycle run too fast how do i test timer control
Wash cycle should run 18 min runs for 8 min
    New Friend:
  • 102 Answers
Hi! It sounds like a faulty timer. You should call the Manufacturer for a replacement or get a suggestion from them. Hope I helped! Thankyou for your question and if we can do anything else just ask!
Posted on Mar 14, 2009
Maytag bravos gets stuck at 8 minutes on cleaning cycle
Probably the timer is hanging. A vinegar rinse won't make any difference.
Aug 21, 2017 | Maytag Washing Machines
Doesn't complete cycle. Gets stuck at 26 mins.
quite likely the control board has begun to fail . only fix will be to get it replaced
May 14, 2016 | Fisher and Paykel 23 in. DD603H SS...
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Bosch SHE44C07UC/22 - FD8606 : pump does not run during wash cycle, but does run during empty cycle. timer works. fill works. empty works. relays are heard about 2 minutes into fill cycle. may be...
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link: LINK - CLICK HERE
Follow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
Jul 26, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
I start the wash cycle timer reads 1:02 machine runs and timer counts down to 54 mins. then resets to 1:12 mins. which inturn adds approx. 18-20 mins to wash cycle why the reset??
I had a similar problem with ours and had a repair guy come out and look at it. He suggested running a couple of heavy bleach cycles through the machine. He said that sometimes if you use too much detergent (especially if you're not using the "High Efficiency" type of detergent) detergent builds up on a sensor in the machine and causes longer than necessary wash cycles. We actually ran 2 cycles of bleach and then a couple more with no bleach or detergent and the problem cleared up.
May 02, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Maytag MAH5500B spin problem
There is a field test you can try to make sure of this.First off ,open the timer panel so you can get the Tech.papers tucked in behind this timer panel.In the paper youll see Field test operational support.Follow that closely and youll get the bad news that is coming after you test the circuit board.Im here to help you so ,dont be shy if you need some help,
May 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
