Question about SanDisk Sansa e200 MP3 Player
Sansa e260 volume will not work?
Boots up just fine and everything else seems to work except the volume- won't turn up. Blue circle seems to adjust everything else except volume.
    Problem Solver:
  • 14 Answers
Try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Posted on Mar 14, 2009
Choppy audio on Sansa e260.
To me it seems like the head phone jack is loose, it might need to be re soldered and then things would be back to normal. HOpe this works.
Wayne
Jun 26, 2009 | SanDisk Sansa e260 MP3 Player
How to turn volume up on radio
Scroll the blue circle to the right when you're on a radio station. that should work...
Apr 30, 2009 | SanDisk Sansa e260 MP3 Player
For Sansa E260 MP3,can't get the volume up. Battery, headset fine
This link will show you how to take it apart. From there I suggest just try and clean it....Hope this works
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
The screen on my sansa e260 wont turn on
hold down the power button for 15 seconds and it shoud reset the whole player
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
No sound, just clicking
try recovery mode. to do this just connect it to your computer and push the hold button so the orange is showing. next push and hold the record button and the power button. it should go into recovery mode.
Feb 10, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Then:
or
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
Screen won't work.
or
-Tha Mp3 Doctor
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
Sansa E260
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
