Question about Saws
I have a CS185L circular saw SUPATOOL it need brushes
I have a CS185L circular saw SUPATOOL i need to replace the brushes but unable to source any can you please help
karmacanic
  • 16 Answers
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
efs_perpends
  • 1996 Answers
SOURCE: Bad brushes
Sounds like it may be time to replace them, no?
If you have a more extensive question, please post back with a reponse as a comment to this thread.
Thanks!
Posted on Apr 04, 2009
SOURCE: Makita circular saw 5007n, it will only run when
Great!! Could you please rate my solution as a "problem solved"?
I would greatly appreciate it.
Posted on May 05, 2009
brewerstool
  • 141 Answers
SOURCE: Need brushes for ryobi circular saw model w-840c
You will probably have to order them through the Ryobi website. I do not think there are any service centers in Australia. I could be wrong, but there are none listed on the Ryobi Website. Heres a link for the parts website: http://www.ryobitools.com/support/parts_batteries
Posted on Sep 18, 2009
  • 165 Answers
SOURCE: I own a Porter Cable model 146 circular saw. I
Try garage sales or eBay.
Posted on Feb 28, 2010
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
I have a Black & Decker circular saw model #7399 which quit working. Are there brushes that need to be replaced and if so where are they?
There is probably an exploded parts list on download from B&D. This would show the brushes. They are under the motor end cover.
Nov 04, 2014 | Saws
What size brushes does the Apprentice 7-14 10 amp circular saw use
www.ereplacements.com they will ask for your model number and the name of the saw. Cost should be somewhere around $20.00 for
new brushes.
Jul 12, 2014 | Apprentice 7-1 4 In 10 Amp Circular Saw...
My Makita circular power saw works then stops working, then starts again. Why is this happening?
Things to check: With the saw running, safely grab the cord by the boot and pull and twist it around. This is where a break frequently occurs inside the cord and when the saw is held in certain positions the break will either open or close. If the cord's OK, unplug the saw and remove the brush caps and check the brushes. If the brushes are less than 1/4" long or the springs are burnt or broke they won't make good contact with the armature. If the cord & brushes are OK your next recourse is to replace the switch (Makita PN 651172-0).
Jan 22, 2013 | Makita 7 1/4" Circular Saw 5007NB
Brush box cap replacement
I think you will find the brush box is part of the main housing.
Dec 08, 2012 | Makita Circular Saw - 15 Amp, 7 1/4in....
How to replace brushes on a DW362 type 2
There are 2 black caps on either side of the saw that hold the brushes in they are # 5 on the diagram
Oct 13, 2012 | Dewalt Dw362 Circular Saws
Need to no where to get brushes and carriers for 18 volt cordless circular saw C18 DL as i have 2 with brushes gone
THEY DONT HAVE BRUSHES ITS A ELECTRIC MOTOR SMALL ONE PART 28 I WOULD THINK THE PROBLEM LIES BEFORE THE MOROR IN THE CIRCUIT OR THE MOROR NEEDS REPLACING PRICES ON THE WEB PAGE IN THE PIC
Apr 21, 2011 | Hitachi C18dl 18v Cordless Circular...
I have the Hitachi cordless circular saw (C18DL) after a good year of use it has stopped working, when I press the trigger the light comes on but the blade does not move and the motor does'nt make a sound,...
It will be the brush holder in the motor has broken.......Ive just had my 4th brush holder break up, The design of them is rubbish!
Im planning on making a hole on the motor casing to accept proper brushes, Ive taken them apart and replaced the broken brush with one out of another motor and bought a faulty one for the brush holder.
Dec 04, 2010 | Hitachi C18dl 18v Cordless Circular...
How do I replace brushes?
two black brush caps either side of the motor - unscrew them pull old brushes out and replace. go to www dot carbonbrush dot com for replacements. or look to eurton electric for brushes.
Oct 26, 2009 | Black & Decker CS1012 7-1/4" 12 Amp...
Saws Logo
71 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
