Question about Canon Speedlite 550EX TTL Flash
Flash won't shoot
When turned on, it appears the flash is ready to shoot, but never fires when the shutter is released on my canon 20D or 10D
  • 78 Answers
Does the red bulb show when the flash is ready to shoot ? you can press the button that lights red or green to test the flash on itself.
Posted on Mar 10, 2009
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
Apr 26, 2013 | Canon Speedlite 430EX TTL Flash
580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Apr 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
http://www.suntax.com.sg/DRF14.html
Apr 01, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Where can I get a manual for this 35 mm camera? Canon does not have one on line.
The dial has six positions. If you rotate the dial fully clockwise, you are at the "Auto" position. In this position, the flash will fire if light is insufficient.
One click counterclockwise from this is "Auto with Redeye Reduction", and a preflash lamp will fire before the shutter to reduce redeye.
The next click counterclockwise is the "Off" position.
The next click counterclockwise is the "Flash On" position, and the flash will always fire with the shutter.
The next click counterclockwise is the "Flash Off" position, and the flash will not fire.
Full counterclockwise is the "Self Timer" position, and the shutter will fire 10 seconds after the button is depressed.
Mar 09, 2008 | Canon Sure Shot 80 Tele/Date 35mm Point...
Canon EOS 10D Shutter getting in the way on fast shutter speeds
Only Canon Technical Support will came to your rescue here
Jul 21, 2007 | Canon EOS-10D Digital Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon Speedlite 550EX TTL Flash Logo
475 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
