Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet lt1050 poor running
Acts like it is running out of gas. changed fuel filter and pump, also pulled carb off and cleaned it??????????????
  • bobby wedgeworth Mar 23, 2009
    it was the fuel shut off solenoid
  • 40 Answers
When you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
My cub cadet modle LT1045 doesn't seem to be getting gas. The fuel filter looks clean. If I spray gas directly into the carb it runs fine but as soon as I stop it dies.
Confirm that the choke is closing completely., Check that the fuel pick up hose does not have a air leak. Confirm that the vent hole in fuel cap is not plugged.(common problem)
Remove fuel line hose to carburetor catching fuel output in a suitable container crank engine and confirm fuel pump is working.
Remove fuel bowl and confirm needle valve is not stuck closed.
Hope this helps?
Fuel Pump
Needle stuck closed
ca4f54cab4d4c1bb583599b331fd2337--small-engine-repair-lawn-mower-repair-u3ralalmkh2yk13xn5gn3lpt-2-2.jpg Check fuel filter
Check vacuum line connection for leaks.
Jul 01, 2017 | Cub Cadet Garden
Cub cadet trouble shooting
i think check for water in gas then fuel filter then rebuild carb thats all you can do and change plug if you havnt already
Jul 24, 2014 | Cub Cadet Garden
Why wont my 12.5 hp kohler engine not run full throttle and loss of power
it sounds like your carb is gummed up. You can TRY something called SEA FOAM (you can get it from Napa), you put it in your gas tank. It's the poor man's tune-up. Otherwise, you can get some spray carb cleaner and pull off your air cleaner and spray it in there. Hope that helps.
Jul 17, 2014 | Cub Cadet Garden
Will start but want stay running gas with oil was put in mower
rebuild carb and clean thje holes in carb with compressed air to get oil out of it clean fuel tank change filter blow out fuel pump with compressdair
Apr 15, 2014 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
Fuel flow on a Cub Cadet 2165 Tractor
Jim. It is probably the jet is clogged or the float might be stuck.Pull the bowl off of it and inspect.
Or try carb cleaner from the auto parts store
Kurt
Mar 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,111 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
