I need a circuit diagram for a Behringer Eurorack 602A, so I can fix it. I also need to know where I can get an ALPS pot, 50k, to replace the broken channel 1 volume control.
    Sergeant:
  • 320 Answers
Try  www.radioshack.com  for parts.
Posted on Mar 10, 2009
  • 10,515 Answers
  • 4,234 Answers
That part can be purchased as a generic part. There is nothing special about it. You should be able to locate one at a local electronics parts store. If you can post your general location, I will try to post a few shops in your area that should have it.
Dan
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer DE2000 De-Esser broken band width pot
Best bet is probably Mouser, http://www.mouser.com Search for the individual catagory. While there is no direct cross, you should have an audio taper or logrithmic tape- similar graphs, but slightly different. It might do well to get one of each and use the one that matches the response of the others.
If however you have a loudness tap- usually 40 percent, that changes the ballgame. Mouser would still likely be the best bet. Over 800 items for pots in the general search at 50K
If your outer trace is intact, you can measure that with a meter to verify that is the range you need.
Feb 05, 2012 | Behringer Music
I have found the fault with my mixer ( UB2442fx pro) but I need to be able to identify 2 components that need replacing. The first is the rotary pot vr96 (aux 3 / fx) and the second is the rotary...
The VR96 is a 50K "G" taper or "graphic taper" pot. Lots of luck trying to find that in a catalog... I finally got a scrapped piece of mixer board and salvaged one. The G taper is not stocked by any of the vendors like Digikey or Mouser here. Full Compass is the Behringer part distributor and I waited 6 months and got no delivery of one of these pots. The effects selector is a rotary encoder quadrature type. Use the Mouser.com catalog. Search for Encoder, then select ALPS manufacturer and then try to match up mounting and type using the spec drawings... with push switch also... Again, if you want to try Full Compass, you can call Behringer rep in Woodinville WA USA to get the Behringer part number and incident number to see if Full Compass might have one in stock.
Here is the maintenance schematics for your unit...VR96 is on page 7 of 32. :
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links as they are for viewers, etc.
Note, You may have to cut off a shaft on replacement to the right length to match existing shaft.
Jul 08, 2011 | Behringer EURORACK UB2442FX PRO Mixer
HI, I just need the value/taper of the 30mm slide potentiometer used in the equalizer of the Behringer K1800XF.
The sliders in almost all of the EQ's in Behringer are linear taper (B). The values are usually 50K. Fo replacement make sure you get matching mounting spacing. Almost all Behringer pots are made by ALPS.
Note that the rotary volume controls are G (graphic) taper, often 50K and are hard to get. trying to get these from the Behringer parts distributor was futile... gave up after 4 months wait.
Apr 28, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
I have the Behringer Eurorack MX 2642A. Over 6 years old. The right main mix output sometimes works great and sometimes gets very quiet and distorted. Is it time for a new mixer or is there possibly a...
It sounds like one of the output devices is going bad, ie., output transistor, capacitor, resistor or maybe just a bad connection on one of the above menitoned items. One other problem which causes this would be the main or sub volume slider or pot is wearing out and needs to be replaced.It would definately be worth your while to have a technician trace down and fix the problem on this board. Hope this helps.
Feb 10, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Dec 15, 2009 | Behringer Music
Pot broke off
Use an ohmmeter to read the value. Even if the resistance element has been broken you can read by touching the remaining part and estimating the total resistance by what is left.
NEXT look for an A or B on the can as this is the taper type. You may also find the resistance marked there like 50K or it might be something like 1003 (100K ohm)
You need to match the resistance AND the taper.
Jan 22, 2009 | Behringer Music
98 people viewed this question
 Grubhead
Grubhead
