Find "Customize"
Press the Navigation key.
Select Profiles.
Highlight General.
Press the Left selection key.
Select Customize.
Select ring tone
Highlight the field below "Incoming call".
Highlight the required ring tones to hear them.
Once you've found a ring tone you like, press the Navigation key.
Return to the home screen
Press Disconnect to return to the home screen.
Yes. go to the profiles.click on any profile.select customize/personalize option. Select the ringtone option. Now u can alter the ring tone by selecting the available ring tones
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
A ring tone can be set for specific contacts on a BlackBerry smartphone that has 32MB or more of flash memory.
To set a ring tone, follow the steps below:
1) Click the Address Book icon on the Home screen 2) Select the contact that a custom ring tone is being added for.
3) Press the Menu key and click Edit.
4) Press the Menu key again and click Add Custom Phone Tune.
5) Select the ring tone from the list of available ring tones.
6) Press the Menu key and click Save.
Try the following instructions, to personalize your Nokia E50! Profiles Warning: In the offline profile you cannot make or receive any calls, or use other features that require network coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls, you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles. You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller groups. To customize a profile, scroll to the desired profile in the list, and select Options > Personalise. Define the following settings: • Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate phone lines in use, you can specify a ringing tone for each line. • Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone. • Ringing type — Select how you want the ringing tone to alert. • Ringing volume — Select the volume level of the ringing tone. • Message alert tone — Select a tone for received text messages. Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
click contacts highlight "call" on the contact your customizing and then hit menu click save to contacts scroll down to custom ring tone scroll to the rin tone of choice. All other customizations done here also.
A possible resolution is to update your device to Windows Mobile OS. For some reason, that seemed to work for customers that have experienced the same problem.
If you're using Nokia fone, go to Contact through the menu and select Caller group. There you'll be able to customize groups for your user. Select a group and customize/edit it.
After you made the ring tone, go to Menu, Ring Styles.
Go to Loud Ring Detail, the go to Messaeg Tone. At the end of the factory installed tones, you will se the one(s) you made. Select it!
