Question about Nikon D70s Digital Camera
Camera showing ERR message and the shutter will not open
  • Anonymous Mar 24, 2009
    Err message flashing, shutter will not release my name is Robert
    email bw1show@aol.com
    216 240 6349
    D702 Nikon
    Scholar:
  • Nikon Expert
  • 115 Answers
Sounds like the connection between the camera and the lens is the issue. Try gently removing the lens. Be sure both camera and lens areas are free of dirt or debris. Be very careful NOT to get any dust, dirt or anything in the camera. That will cause bigger problems yet.
Posted on Mar 14, 2009
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Canon error 99
.1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99' message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99' message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99' message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99' with a different Canon lens attached, then the
camera should be serviced.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Error blink in place of shutter indicator
I AM SAGHA REPAIRER FROM MUMBAI I THINK THERE ARE PLENTY OF REASONS SHOWING ERR ON TOP DISPLAY BUT IF ERR IS SHOWING JUST BY TOUCHING THE SHUTTER RELEASE BUTTON THEN THE MAIN BOARD IS DEFECTIVE.IF ANY MECHANICAL ACTION OCCURS AFTER PRESSING SHUTTER RELEASE BUTTON AND THEN ERR APPEARS THEN THE FAULT COULD BE OF SHUTTER & APERTURE BLOCK.I THINK ALL THESE SOLUTIONS ARE FOR EXPERTS AND NOT FOR GENERAL USERS IF ANYBODY FINDS THEM USEFUL LET ME KNOW & ALL THESE ARE BASED ON MY OBSERVATION ABOUT FAULTY CAMERAS.
May 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Nikon D70s Digital Camera Logo
146 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
