Question about Refrigerators
Ice doesn't come out into glass. Makes some ice but is larger pieces stuck together or flat pieces in bottom of container. Green light in back of container is on. I set the freezer to colder temp but didn't help. Turned the whole refrig. off and back on. Didn't help. The water side works ok.
  • Refrigerators Master
  • 3,361 Answers
You are not using enough ice.
You may need to dump the bin every week or so and keep fresh ice in the bin.
When you go through several defrost cycles the ice tends to eventually melt and stick together.
Posted on Mar 10, 2009
Green Ice from ice maker
Make be free copper pipe corrosion.
Jan 10, 2018 | Refrigerators
Blinking green light
I get a blinking green light in my freezer when a piece of ice gets stuck instead of dispensing into the ice bucket. First break the stuck ice off then there is a switch beside the green light that you turn off then back on. You should be go to go again until the next time. Mine does it alot and I have a friend with the same refrigator and the same continous "stuck" ice.
Jun 25, 2012 | GE GSH25JFT
The ice and water dispenser not working after being perfect for 12 months. the light still works when glass depresses back.There is no light indicator on the symbols.Ice maker is still making ice.
Its possible that yor water line is clogged or your water valve is stuck; will need take oof the cover to check it. First try defrost few hour to test without take off nothing.
Jul 20, 2011 | Refrigerators
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Ice maker does not make any ice green light flashing in freezer
There was a small piece of ice stuck in the back prongs. Removed stuck ice (very small but enough not to make it work). Now it works GREAT!
May 15, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
