Question about Weather King 10PJA2501AH Air Conditioner
Compressor is Down
Hello we had a snow storn in ky on feb. no power after everthing came normal my heather star to have a problem. I contract a company they say the compressor is down they say i have to change, sear changes dictate mandatory replacement..They say i need a new system..My house is only 4 1/2 year..i call the insure they say i need call another company to go and look my system i did and now they say only i have to changed is the compressor. Is good to change only the compressor? Do you think i will have problem latter? please lets know because the first company tellme if i changed only the compresor i will have to have problem latter.
Thank you for you help
  • 3,361 Answers
Changing the compressor and capacitor and filter dryer should be no problem.
How old is the system? It may be under warranty. Most systems are 5-10 year warranty on the sealed system. That inckudes the compressor.
What exactly is the system doing or not doing?
Posted on Mar 10, 2009
    Scholar:
  • 144 Answers
It depends on how old your system is. A heat pump that is 7 years or older I would recommend replacing the system and not just the compressor. Yes the first company is right in saying that you have to install a higher S.E.E.R. system (assuming yours is less then a 13) that is an EPA law. You can replace just the compressor however, if the system is older then 7 years you will start to have other parts breakdown soon. It's less expensive to replace the compressor but in the long run it is more cost effective to replace the system for both future repair and operating cost reasons. Good luck and don't forget to give me a Fixya rating.
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
Why does it run only in the start position?
Hello Martin, Your generator might have a low oil pressure shutdown switch. First check the oil level. If oil level is low, fill oil to proper level. If oil level is fine, I would install an auxiliary oil pressure gauge . If oil pressure is normal, I would change the oil sender unit. If oil pressure is low, I would change the oil pump.
Aug 03, 2015 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
How do I connect to internet
It must be able to connect to Wi Fi and you must have Wi Fi in your home.If you have both you can use the setting and set everthing up. make sure you have your Wi Fi Ky code
May 10, 2014 | LeapFrog LeapPad2 Explorer - Green
Fridge is way too cold. everthing freezes. Ive turned control all the way down, but the compressor is still running constantly
Your fridge has a thermostat control problem, replace it with similar rating and size, it will go back to normal operation.
Jun 16, 2011 | Refrigerators
American standard heat pump some body before me changed the compressor unit would not work so i pulled vaccum weight in charge started uint after 5 min. it triped on compressor overload everthing else...
Check all of the wires to the compressor, if the internal overload is opening you may have to replace the compressor. if it is an external overload and the amps are normal it could be a bad overload switch.
Nov 01, 2017 | Heating & Cooling
Ph level is high
Heather,
leave it alone for a week
If it is still high then get a bottle of ph down.
Make sure you go slow otherwise you might find yourself needing to boost it again.
Jun 21, 2010 | Intex Automatic Salt Water System for ...
I have a kenmore s x s refridge and the freezer is cool by everthing is thawing out. I hear a clicking noise so I took the back cover off and it seems to be coming from the compressor.
the clicking noise may be coming from the start and oveer load relay on the compressor shut the unit down until the compressor is cool replace the over load and start relay on the compressor.
if you have a clamp type power metercheck the current draw on the compressor it should be between 1.2-1.6 amps during a running load.
May 19, 2010 | Kenmore Refrigerators
Sunbeam KY-25 portable air conditioner not working.
Mine works but with a bad exhaust fan, want to sell yours?
Apr 26, 2009 | Soleus KY-25U Air Conditioner
Weather King 10PJA2501AH Air Conditioner Logo
87 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
