Question about Moen Lavatory Rough-In Valve with Drain Assembly 9000
Moen 9000 rough in drain assembly installation
Drain assembly leaves a hole at top, obviously a place for water to flow out of drain into cabinet below.
    President:
  • 2,692 Answers
If I understand correctly,Your basin bowl does not have an overflow passage vent. You will need to puchase a different drain,tail piece, that does not have the side vent hole.
Posted on Mar 11, 2009
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
We just installed a new moen 4 inch centerset Lindley faucett with drain for our bathroom. The drain piece has 2 molded holes in it. We are experiencing leaks from this pipe. How are we supposed to fix...
Ok I asked for some more information, but let me give it a try to help you with what I have here.
The two holes are for water to drain out of the over flow of the sink. If you look at the sink on the front side you may have to feel but there is one hole or up to three little ones. They take off water when someone walks away with the faucet on and they it goes down the drain and not on the floor.
Now if the sink your putting this in is a steel sink that does not have an over flow it will leak and you need an other drain system that is made for a sink with no over flow.
Places like manufactored homes, boats, campers would be where you would find a sink that does not have a over flow. Now with the over flow out if the sink does is not about1 inch thick.
if not use try more putty
Sep 12, 2011 | Moen Bathroom Sink Faucet - 4-inch...
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
I have a 15 year old Moen bathfaucet 4650-P that I want to replace. I can't figure out how to remove this old faucet. It has three holes with the outer holes on 4 inch spacing. The two handles and the...
There is definitly a nut or nuts holding the faucet to the sink. It could be around the center shaft that goes through the sink, but most likely 2 small nuts that screw onto the 2 outer stubs. These are your hot and cold wated supplies. crawl underneath the cabinets and check. It might be difficult to get them off, but they do make a pipe wrench tool that has a rotating head that makes this easier
Mar 04, 2011 | Moen Home
The hot side of my Moen 9000 rough-in assembly leaks from the faucet when the water is turned on underneath the sink. Possible solutions.
I'm sorry to hear you are having issues with you 9000 rough-in valve. You may need to replace the hot cartridge.
I recommend that you contact our customer service to see whether your product is under warranty. The number is 1800-BUY-MOEN. Hope this helps!
-Olivia from Moen
Dec 20, 2010 | Moen Lavatory Rough-In Valve with Drain...
How to drain radiator
hello. on the drivers side of radiator is a drain. here is a picture and the instructions for draining the coolant out.
  • Install a tube on the radiator drain. Place the end of the tube in the drain pan.
  • After the engine cools down, remove the radiator cap.
  • Completely open the radiator drain ****.
  • Allow the coolant to drain from the system until the flow stops.
  • Place a drain pan under the block drain hole plug.
  • Remove the drain hole plug from the engine block.
  • Allow the coolant to drain from the block until the flow stops. There may be more drainage from the radiator at this time.
  • Install the block drain hole plug.
  • Close the radiator drain ****.
    Jul 04, 2010 | 1997 GMC Suburban
    Handle is loose water flow weak
    to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
    Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    BOSCH SHV68 DISHWASHER
    All D/W should have what they call a high loop to help prevent back flow from sk to D/W. you can remove the rubberband and place the hole at the bottom take the drain hose run to top of cabinet and fasten will be fine for high loop any excess hose just tuck out the way
    Jan 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    Moen Lavatory Rough-In Valve with Drain Assembly 9000 Logo
    313 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
