Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener.Working off and on. Green light blinking
Its an older '95 Craftsman opener. HBW077. It will work from the wall most of the time, but the remotes only sometimes. I have reset the remote codes several times. The ground sensors are inline. There is a green light that blinks rapidly on the back of the motor. It has worked great up to this point, but there is nothing in the manual about that blinking light which has to be signaling some kind of problem. Any help would be greatly appreciated.
Check the alignment of the safety light beams near the floor on each side of the door. They are not properly aimed and the safety reverse feature will not allow the door to close properly.
Posted on Mar 10, 2009
HBW077 Craftsman: door travels downward only 10"
Sounds like you have a bad RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it hits an obstacle but will act as you describe when they go bad. The part number is 41C4398A and is available at Sears or any good door service company.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster HBW077. The opener operates from the wall mounted button. There are two remotes and neither will open the door. The green light on the WALL button is blinking. There is nothing that...
Check to see if the wall control has 3 buttons. If it does one of them is the lock button and you need to press and hold this for 3 seconds. The lock button has an icon of a padlock. If you do not have a 3 button wall control programming the remotes should cure it.
Dec 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Garage door opener (139.53800SRT)was working and then just quit working. None of the remotes or wall switch work. When I press a switch I hear a few click in the opener and then nothing. ...
The code for 5 flashes is " Motor overheated or possible RPM sensor failure. Unplug to reset." Also if the door is stuck in the open position it could be the trolley is jammed against the bolt just in front of the motor unit.
Feb 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door don't open
On the wall control press and hold the button with the lock icon for 3 seconds. The blinking should stop and your remotes will once again work.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Remote Openers Stopped Working Suddenly
Check the wall control. If the small green light is blinking press and hold the button with the lock icon for 3 seconds.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
The wall button has a green light that is blinking and the car remote will not operate the garage door but the wall button works
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
hope this helps someone out there
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
594 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
