Question about Hitachi Deskstar 7K1000 750 GB SATA Hard Drive
I added an SATA HD to a system whose C and D drives are a WD 400GB PATA HD. The Hitachi 750GB drive has no jumpers for master/slave. After boot-up the system sees it but assigns no E or other letter designation. The HD came with no documentation and the motherboard manual only mentions where to find the SATA connectors.
  • 35 Answers
  • Right Click [My Computer] and click Manage
  • Click Disk Management on the left side
  • Inspect the drives listed. The new drive may need to be formatted for the operating system to recognize it and assign it a letter.
  • To format the drive, right click the drive with no letter, and click Format. Choose your format (Preferred NTFS), and quick format the drive so that windows recognizes it.
Posted on Mar 10, 2009
  • 78 Answers
You need to check the drive manager in the control panel / admin icon. In here you should be able to see the drive and format it because if it is a new drive windows will not detect it as an acceptable drive before it is formatted by drive manager.
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Cant find the slave drive on boot
Master/Slave configuration I am assuming you have IDE hard drive and not SATA. SATA is a small cable IDE is a wide 40 wire flat cable. You must install the jumper on both drives as master and slave. On the old WD HDD master has jumpers between 5 and 6 and slave jumper between 3 and 4. Default is jumper between 1 and 2 which is cable select which you use for a single drive.
Nov 09, 2013 | Dell Inspiron 531s Desktop Computer
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
Hard drive won't reboot (jumpers not set proper)
Just google your drive's make and model and search the results for a diagram of the jumper settings.
If you have a SATA drive, there ARE no jumpers. If the drive is a PATA, then if it's connected with another drive or cdrom, then make the cdrom 'slave' and the disk drive 'master'.
Check your bios setting sometimes bios changes the boot order esp. if bios doesn't find a boot disk- make sure you have your desired boot device showing in the boot setup.
Oct 31, 2012 | Hitachi Computers & Internet
I have two hard drives in my tower How can I make it boot so that both hdd show in one os And it goes straight to windows
Windows will see both hard disks when Windows opens up.
For IDE/PATA hard drives the boot hard disk (C drive) must contain the Windows operating system and it must be jumpered as the Master drive. The other hard drive must be jumpered as a Slave drive if it is on the same data cable as the Master drive.
After Windows has been installed and this Slave drive has been partitioned and formatted Windows will see this hard drive as D: Drive which can be used as data storage etc.
If you have SATA hard drives you need to connect each SATA hard drive on its own SATA cable/controller.
Apr 09, 2011 | ASUS Computers & Internet
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Motherboard is not seeing the HD
generally its not a good idea to run both ide and sata drive at the same time.
if you are lucky in your bios it will have a emulate sata as pata/ide drives.
turn this on and be sure to select the ide drive with the OS on it as the master drive so it boots first.
also if you are doing this you will also need to change the jumpers on the sata drive as well to make it a slave and not a master otherwise you will have two master drives and it won't boot.
good luck
smeags
Jan 09, 2008 | Intel D865GBF Motherboard
Hitachi Deskstar 7K1000 750 GB SATA Hard Drive Logo
356 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
