Question about Bose Around-Ear Headphones - Silver
Fixed broken headphones but sound quality has plummeted
My headphone wiring got messed up at the plug (left headphone works but right headphone doesn't). I recently purchased a replacement jack from radioshack for 3.99 and i've cut the wires, soldered them onto terminals, etc but the sound quality is significantly worse. Do different jacks effect sound quality or is it because of a poorly done soldering job?
on a side note: i have Bose around-the-ear headphones
should i resolder the wires or purchase a better jack..
where can i find a better jack if thats the case?
  • rjr62 Apr 17, 2009
    I ahve the same problem. Sound only comes out of one side now, as a small tear developed in the wire near the jack.
  • socampbell May 24, 2009
    I've been looking nfor a replacement jack for the over the ear headphones. The left side wire was torn from the male connector. Tried to replace with the extention that comes with the headphones, but it's a diffent set up with the wires.
  • 181 Answers
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Posted on May 24, 2009
No sound in left headphone
Yes, sure. But it's a bit difficult, because you have to find the broken piece of it. Look for cuts in the wire. If you can see it, you can cut the protecting piece over the wire open or off and connect your wires again. Melt them together and it should work.
Jan 02, 2014 | Wesc Bongo Headphones
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
Only right side works
hello rrwunsch!
please check wiring first to find out if headphones broken or it is a connectivity problem. for that, if you connect with rca plugs - change right to left and vice versa. if still left headphone has no sound so the speaker is blown. hope it is only wiring problem.
regards
Feb 20, 2011 | Sony (MDRRF925RK) Consumer Wireless...
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
Ive a problem with the volume of the headphones, the right one works fine but there is no sound from the left side....ive tested the headphones on other electronic equipment and the headphones work the...
Hi,,in most cases what causes one side of the headphone to work is because, the wire that is connected to speaker inside the headphone might have cut and it's not contacting properly.
What you will need to do is to open up the head phone (left),and check if the wire inside has not cut, If it has removed ,then you will need to put it back with soldering iron and a lead...
But if the wire inside has not removed and they are intact, then you will have to replace the left speaker .
Hope that helps...
Thanks for using fixya...
Nov 08, 2010 | Audio Players & Recorders
My left earpiece in my sentry headphones have no sound. How do I fix this?
Check the plug - it might have a broken wire, by wiggling it in the jack. It could be the jack as well - try another headphone in the jack.
Nov 08, 2010 | Sentry HO900 Headphones
My skullcandy lowrider left headphone won't work on my iPod touch
Wiggle the plug once it has been plugged in and the radio is on. If it is intermittent then it's the male plug. This is a common failure. If you are able to solder then you can get replacement plugs at Radio Shack. If there is no change, and there will be if it's the plug, then the problem is in the wiring or the speaker. If it looks easy to disassemble then check it. All you will have is two thin wires and a strand of white nylon, (for strength). It will require a bit of soldering but it's relatively easy and worth the effort if you like the headphones. If the wires look ok then most likely it's a separation in the wiring. If that's the case save yourself the headache and toss them.
Sep 20, 2009 | Skull Candy Lowrider Headphones
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
Bose Around-Ear Headphones - Silver Logo
1,105 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
