Question about Dryers
Installed new glow tube but found out it is not getting any power to ingnite it, not sure where to go I did check saftys and they were all closed.
  • 2 more comments
  • brian436 Mar 10, 2009
    I'm not sure I understand where is ingniter mod located because I do not have any power to glow tubeand check all connections
    where is main board located
    I will not know till I try it
  • brian436 Mar 11, 2009
    I have tried all the trouble shooting that has been told to me and I thank you all for your help, but I still do not have power at the glow tube and I'm not sure why . I guess I will call a service man and it kills me to do this I have been in maintenance for 25yrs and never have had this problem before. I guess i'm just getting old for this.
    Thanks
    Brian
    Sergeant:
  • 300 Answers
How to Repair Electric Furnaces
http://home.howstuffworks.com/how-to-repair-electric-furnaces.htm
and also where the fuses are located in the unit to check out
http://home.howstuffworks.com/how-to-repair-electric-furnaces2.htm
for Troubleshooting Electric Furnaces and Electric Heaters
http://home.howstuffworks.com/how-to-repair-electric-furnaces1.htm
click the links 1 by 1 and check out.
thanks.
Posted on Mar 10, 2009
    Sergeant:
  • 320 Answers
This is the basic.. It may varies by company.
Tstat calls for heat..
Power goes to the control board.
Power turns on the small inducer fan..
Pressure switch(s) closes.
Power from pressure switch goes though temp limit(s) switches.
Then goes to the ignitor modular
Modular then turns on the ignitor.
    Brigadier General:
  • 8,619 Answers
Hi!
Check the wiring from selector switch to the coil. Also check for the relay on the control board it might be loose or burnt
  • 728 Answers
Look on the main board and check for any blown fuses because if there are any, it will not allow power to pass into the glow tube.
  • 10,515 Answers
Be sure the belt is looped over and around each pulley correctly. There also has to be a tensioning arm (lever) that must be tensioned correctly and enough to activate a micro (tiny) switch.
Not exactly sure how that setup works. But the point here is that tiny micro switch has to be activated, if equipped with one, to allow the hot surface glow ignitor to operate. If not, the rum will rotate but the ignitor will not turn on. Without ignitor the burner will not turn on either.
First place to check is on the control panel. Be sure all selections are correct. Than recheck the timer selector setting. Than access the burner viewing area, usually through a door panel access.
Once all the is done, turn machine on as normally done.
Watch the burner area. The glowing hot surface ignitor should activate. You will hear a tiny click just prior to the glow ignitor beginning to glow. If that happens, allow a few moments of time to pass.
A second click should be heard shortly thereafter. The second tiny click heard will or should turn on the gas inside the burner valve and the burner should than fire up.
None of the above will happen if the glow ignitor is broken or defective. The hot surface glow ignitor is the part very close to the front of the burner tube where the flames would be. Check to verify the ingitor is not broken.
The ignitor may be a flat white bar with extended gray colored tuning fork like elements. It will have a protective thin metal covering. Or it may be a round coil of gray material covered with a thin metal covering.
The gray surface area is the element, which will glow when electrical current is applied to it. The color will start out orange and turn a bright yellow orangish color. When it reaches the correct temperature, the second click will be heard.
At this time the burner gas will be allowed out of the gas control valve and the ignitor will ignite the gas. Flames will appear.
  • taran_2005
    taran_2005 Mar 10, 2009
    TROUBLESHOOT IF EVERYTHING WORKED OUT RIGHT
    The ignitor coil must glow. It must be HOT and glow an INTENSE bright yellow orange color. If not, it's considered to be burned out. If it fails to glow at all, it's also possible it's completely burned out.
    Other items you may need to do or want to check/do {whichever applies} while your in the process of repairing the dryer.
    Restricted Exhaust Vent:
    The vent tube is located behind or to the side of the dryer. It needs to be removed totally from both sides to completely clear out the lint.
    Check the entire venting system. This also includes the exhaust vent hood outside. It has a flapper that may not be opening fully or not at all. Locate any restriction within the entire exhaust system and clean out all lint. Replace exhaust vent tubing as needed. Plastic vent tubing is fine.
    Defective Solenoids:
    There are two...both are on top of the gas valve.
    Solenoids also supply voltage to the glow coil and are part of the electrical loop. All terminals on both solenoids must have continuity. If not, you'll need to remove them from the top of the gas valve by removing the entire gas valve assembly first.
    Remove both solenoids off the gas valve body by removing the holddown cover plate and replace them both if defective. They are sold only in pairs. Or take the entire gas valve unit to your local appliance parts store and have the entire assembly and all the parts tested individually and as an assembly.
    Defective Gas Valve:
    Remove entire unit as an assembly. Take the entire assembly to your local appliance parts store for testing. Gas valves are not repairable. Replacement is the only option if defective.
    CAUTION: Do Not attempt to repair the gas valve! This is a non repairable item!
    Defective Glow Ignitor:
    It's a rare possibility but worth noting here. The glow ignitor may glow but just be too weak to allow current to continue to flow to the coils. The solenoid coils are also part of the electrical loop and may effect proper glow ignitor operation or functioning.
    Timer:
    Control center for all functions. The timer has internal contacts and as it advances through the cycles, one of those contacts can become burned out, stuck opened or closed for any one of several reasons.
    Timers also have cams that open and close those contact points. If the timer hangs-up on a lobe, it may or may not advance to the next cycle.
    If the timer or any other selection switch, on the front control panel, is suspected of causing the existing problem you're having with the appliance, be sure all selections are correctly set.
    If they are, the timer or other function selected switch may be defective. Timers are a non repairable item. Any or all of the control panels switches can be removed and taken to the local appliance retail parts store for testing.
    Timers and switches can also be checked for continuity using an ohm meter or continuity tester. However, do not rely soley on a continuity test for proper timer functioning. Timers and switches are a non repairable items.
    A Fuseable Link:
    Check for continuity across this part. It will be located in the exhausts venting system prior to the discharge outlet. If there is no continuity, replace the part. Not all dryers have this part.
    Flame Sensor:
    This part is located on the burner housing. If it's defective, it will cause the glow coil to not function or cause the problem your discribing. You can test this part with a continuity tester or an ohm meter.
    However, do not rely on the continuity test to prove the part is functioning correctly. The only proof positive method to be sure the part is functioning correctly, is to carefully remove the part and have the local appliance parts store person do the testing.
    Door Safety Switch:
    The door safety switch {that extended button in the door frame} is the part that pops out when the door is opened. This button controls the entire operation of the dryer when it's running. If it fails to pop out or the switch fails to disconnect internally, the dryer will not shut off when the door opens. Neither will anything on the appliance work if this button does not make internal contact when the door is closed.
    Safety Reminder:
    ALWAYS be positive you have unplugged the electrical power and turned off the gas supply to the appliance prior to attempting any repairs!
    FYI:
    The do-it-yourself person can do electrical tests and continuity tests on several of the parts. There are parts such as flame sensors, timers, solenoids, gas valves, etc. when neither of these tests will provide proof positive the part is actually functioning correctly. Therefore, do not rely solely on either test.
    TIP:
    Best method is to determine if any part is funtioning correctly is to carefully remove the part or parts you suspect to be the potential culprit, and have the local appliance parts store person run the required tests.
    Top Expert:
  • Dryers Master
  • 79,077 Answers
Chances are the ignitier module has failed, any appliance parts store can supply this part.
  • yadayada
    yadayada Mar 10, 2009
    do u have gas flowing out the burner?? if not the gas valve is most likely defective, if it does flow it is most likely the igniter or the igniter control circuit.
Gas oven will not light or open valve, Brand new ignitor
The igniter will not glow unless the gas valve is operational. The gas valve will not open unless there is power to supply the igniter. Igniters have a low resitance (20-100ohm). So, you can test it. Normally there is no power going to the ingniter.
You may have a defective gas valve (usually the safety circuit). The valves are not repairable (it would be dangerous to attempt it, and there are no parts available). So, you must replace the entire unit.
The thermostat may be shorted. If that's the case, the valve thinks the oven has reached temperature, so it doesn't need more heat, so the igniter won't glow, so the gas won't flow.
Jan 20, 2014 | GE Profile JGBP79 Gas Kitchen Range
I just replaced the oven igniter in my maytag FCG20600B and it will not turn on. The Broiler igniter works but the oven igniter will not. is there anything else I can look at? Thank you Mike
does the ignitor glow?if so make sure you installed it so it's sitting close to the tube,i've seen them put in upside down,also check to make sure the tube holes are clear so the gas will ignite next to the ignitor.you'll have to check with a meter to see if power is going down to the ignitor,you could have a bad relay in the clock assy.or remove the back and check for loose wires,also look at the tube,i've seen weak ignitors burn a hole into the tube.how did you connect the new ignitor,did you connect it with wire nuts,if so remove the wire nuts,make sure the wires don't touch any metal,with your meter set on volts see if power is coming down to the ignitor,also did you check your old ignitor to see if it was bad?set the meter on like 20k,touch the leads to the wires on the ignitor,if you get any reading it's good if it stays on1 the ignitor is bad.check the wires on the gas valve to make sure it's not loose
Apr 02, 2011 | Maytag Ovens
Kenmore Gas Range. Top burners work fine. Oven is slow to preheat. Igniter has a yellow glow and the burner lights within about 20-30 seconds later. However, the burner has a very small flame and it takes...
the ignitor should glow bright orange.it sounds like you have a weak ignitor but if the flame lites within 20 to 30 seconds it sounds like it's ok,it could be braking down though when it gets hot,it doesn't matter if it glows,it has to be putting out 3.2 amps,if you have an amp meter with a clamp on it you can read out the amps,if the broiler works ok i would change out the ignitor,then follow the tube down to the bottom and stick a paper clip in the orifice hole where the gas comes out and make sure that's clear,also there's a shutter on the tube to adjust the air flow,see if it's closed,it's usually almost wide open,check the tube to make sure the ignitor didn't burn a hole through it.i've found tubes with holes in them from a lazy ignitor,most of the time if there's a problem it will be the ignitor
Jan 23, 2011 | Ovens
I have 20 inches tv there is a sound but no picture,it so dark picture
Since you say dark picture visible, then : Brightness control setting!
Check the resistors on the neck PCB. If you find the resistance value of these resistors high, replace them.
If No EHT is found then also there won't be a picture visibility.
1. Open the back cover and see whether you can observe a faint filament glow in the picture tube neck, close to the picture tube socket.
If there is no glow E H T circuit failure.
2. If the glow is observed check picture tube grid voltages grid no. 2. as said above.
( the points referred above are all for technical people)
Oct 15, 2010 | Televison & Video
My gas drier turns the heat on for a minute or so and turs off.
Sounds like the glow bar is comming on but no flame. Make sure the gas is turned on.
If still not working the problem might be one of the safty coils on the top of the gas valve may have an open circuit or the glow bar sensor may have an open circuit.
Depending on your skill level
unplug the dryer and shut off the gas. Using a multi meter check the resistance of the safty coils on the gas valve. There is a coil replacement kit you can purchase to replace the gas coils. Check the resistance across the glow bar sensor. It is located on the gas funel. It is a little black box with two wires comming from it. It should be a closed circuit untill it senses the light of the glow bar then the circuit will open allowing the gas valve to open. If open, replace.
Dec 27, 2009 | LG DLG5932W Gas Dryer
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Craftsman rideing mower
try checking the brushes in the starter motor
or putting direct power to the starter
Sep 11, 2008 | Garden
Oven, Broiler will not ingnite
ok try this turn the bottom oven on count to thirty then smack the safty valve with the plastic end of a screwdriver its the square box with two wires on it that the burner tube goes to underneath if it lights replace it
May 26, 2008 | Magic Chef 31100 Gas Kitchen Range
Dryers Logo
Top Dryers Experts
