Question about HP Pavilion dv9000z Notebook
Hp pavillion zd7000 notebook unstable connection
The plug in seems to be bad...have to wiggle the power cord to get it to work
  • ljwhite58 Mar 12, 2009
    Can you point me to the guide
  • rvsocha Apr 08, 2009
    laptop will not turn on. no power lights indicated on pc. power cord has green led light on.
    President:
  • 2,653 Answers
This is a common problem with laptops.
You can go the DIY approach for a cost of $10-30 and 1-3 hours of your time; or have someone with experience repair the laptop for $80-120 dollars.
If it's worth it for you to go DIY, let me know and I'll point you to a guide.
Posted on Mar 10, 2009
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
My girlfriend walked by my asus 1015pem and her foot caught the cord and tugged on the netbook pretty good. the plug in/out of the battery cable still functions and charges properly, but there does seem...
You are very lucky the notebook did not bounce!
Yes a small amt of wiggle is normal. I would advise against "checking" it too much. (Applying more wiggle may not help the situation)
If at some future date you experience issues with keeping power connected, you will know what to check first. I think you'll be fine.
Feb 09, 2011 | ASUS Eee PC 1000HA Notebook
I have a HP Pavillion DM1-10. Everytime I plug in my power cord to my notebook it says 22% plugged in, not charging. I'm worried that my notebook is malfunctioning so I hope you can give me some advice to...
Your notebook may be fine. You should check your power cord for any cuts or breaks. The power cord may have gone bad. You can check by feeling if it gets warm when plugged in. If not, you will need a new power cord.
Nov 05, 2010 | HP Pavilion dv6000z Notebook
I think there is a connection problem, where the p...
Get one of those JerkStopper plug-in. Really keeps cord from moving. on HP ZD8000
May 20, 2010 | HP Pavilion zd8000 Notebook
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Appears to have a bad power supply where to start troubleshoot
I would start with the AC jack. Plug the power cord into the jack and see how much it wiggles. If it does wiggle, try to see if the jack is wiggling inside the computer. HP had a huge problem with the ZD7000 models, the AC jack would break free from the soldering on the motherboard. Solution at that time was new motherboard! Since then you can now find folks to fix the motherboards.
But this also could be the power adapter. Is there a light on the adapter? You could check for power with a multimeter.
Mar 25, 2009 | HP Computers & Internet
Laptop hp pavillion zd7000 power adaptor
Here's a power adapter:
http://store.l-f-l.com/cgi-bin/cp-app.cgi?pg=prod&ref=350775-001
Jan 23, 2009 | HP Pavilion zd8000 Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion dv9000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
