Question about Canon imageRUNNER 2000 Copier
1/4" weak, blurred line from top to bottom of page on every copy...has new drum, cleaned optics and glass, including **** glass...
  • 523 Answers
Hi, if the class is clean and the drum is not bad, this means is the fuser unit role cause this problem, but sometimes the cleaning blade too do this when it becomes bad and it doesnot clean the drum well. to help you trouble shoot this problem do this:
open the document feeder donot put any paper on class, and hit start, let the ,machine copy when the feeder is up and no paper, the copy will come black paper, check it if u still see the line there this means the fuser, if not its cleaning blade or drum.
let me know wat happen and if u have pics will help too.
Best Regards
Posted on Mar 10, 2009
When I make a copy, I get a blank strip running from top to bottom near the middle of the page?
Do the lines show up when you make copies with the adf and the copyboard glass?If it shows up on both you may need a new OPC drum & cleaning blade.
Sep 02, 2011 | Minolta EP1031/1031F CS/PRO Copier
I have a Kyocera CS-2050 and there is a dark line that prints in the center of the pages. What causes this and how do I correct it?
Several things can cause this if it does this when copies are made on the doc feeder try making copies on the platen glass (the main glass). If the copies on the platen don't have the line its the **** glass the small line of glass left of the main platen glass. Clean with windex or alcohol. If it does it when any copies are made and doesn't do it when prints are sent from the computer Than the optics (mirrors) need to be cleaned. If it does it from prints from the computer than it might be the charge wire. To clean this open the front door and next to the waste toner bottle their is a slim green tab. Pull it out until it stops do this several time. If that doesn't fix it it might be the drum look for a line in the drum hold the page next to the drum to see if the line lines up with a deeper impression in the drum. Maybe the fuser unit do the same with the fuser (the unit that gets hot) and see if the teflon is worn off (will be a gray line were it has worn off.
If you have anymore questions just ask.
Hope this helps.
Aug 25, 2010 | Kyocera CS-2050 Black and White Copier
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Copy is not clear
Hi
The first thing you must check is the small scanner glass,this is the narrow glass that the machine is using when you use the dockfeeder,clean that glass and make sure there is no back dots on the glass.Even a small dot can cause lines on your page.But this lines will only be sen if you using the docfeeder.
The second probem can be the drum cartridge that is faulty.With this problem all your copies and printed pages will have lines.
If your drum is ok,the next thing that goes wrong is the fixing assy.
Jan 23, 2009 | Canon imageCLASS D320 Digital Copier
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Thanks,
Aug 30, 2008 | HP LaserJet 2840 Printer
WEAK COPIES ON XEROX COPIER
You need to 1 remove the glass and clean the mirrors, lens and bottom side of the glass.
Also, remove the toner and drum cartridge, use a flash light. On the left side you will see a "window" about 5/16th of an inch in height, and probably 5 or 6 inches wide. That is the laser window, it is probably pretty dirty. You may have to use a Q tip or a soft cloth, dampened with some glass cleaner, and clean that window well.
If the optics, and laser are dirty , hazy, the copies will be light and streaky. The drum may be bad. Also, on the right hand door, Look just above the rollers, there will be an opening, it has a small clear plastic guide, then open with a hair fine wire running through it. Take a Q tip dampened with some alcohol, and carefully clean that wire. You can apply light pressure to clean it, just don't get forceful, it does not take a lot of pressure to clean that wire. That wire is responsible for "transferring" the ink from the drum to the paper.
If you clean all 3, Optics, Laser window and transfer wire, I think you will be very very pleased with your copy and or print quality. That should restore it very well.
Apr 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
Canon imageRUNNER 2000 Copier Logo
51 people viewed this question
old marine
old marine
