Question about Kitchen Ranges
My wall mounted univa oven will not work the temp light comes on but no element or oven light comes on. happened all of a sudden worked perfectly previous day. the 4 plate countertop still functions and it uses the same power supply.
The T300 over temp safety devise at the back top center of the oven behind the back sheet metal cover has functioned
This means your oven reached 300 degrees centigrade plus
You need to replace this but also check why it over heated
You should check out your oven thermostat to ensure its not going to max tem immediately
regards
Posted on Aug 29, 2009
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Both the bake and broil oven elements do not heat up / they are unresponsive. I can set the oven temp but on the control panel and it appears that everything is OK there I've replaced both elements and...
Must check the the voltage of 240 coming in to the oven sometime there is 120 volts which will light up the control panel but not enough to turn on the heat elements also check the wiring diagram some times there are cut off switches between the control panel and heat elements those can be bad too!
Appliancetek
www.astrepairs.com
Jan 14, 2011 | Ovens
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
240V wall oven,digital readout and oven light come on but no heat
Bad clock assembly although the clock works the solid state switches internally typically go bad even on brand new ovens,does broil work,the top elements should work?
Jan 21, 2009 | Ovens
Kitchen Ranges Logo
499 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
