Question about HP Color LaserJet 5550hdn Printer
HP 5550c Printer: install a toner cartridge and now the cartridge is jamed and unable to turn the toners as before. can not remove the cartridge.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Do you mean a HP 4550?
    Problem Solver:
  • 12 Answers
The white plastic lever has broken and needs replacement. On the bottom left hand side bracket of the Transfer kit to it's left is a black plastic cover which pops off remove it and you will see a white plastic
lever which pivots on a bar with the transfer kit locking and unlocking the toner cartridges it often goes bad and tears. Hp should modify this and make this piece metal not plastic. You can manually pull and push down on the metal bar to lock unlock the toner cartridges for a temporary fix.
Posted on Nov 22, 2009
10.10.00 SUPPLY MEMORY ERROR after every page prints.
This means that the printer is unable to read or find the toner cartridge memory chip. In some cases turning the printer off, removing the toner cartridge, reinstalling the cartridge and turning the printer back on sometimes correct this issue. But if that does not work, you will have to replace the toner cartridge.
Feb 22, 2011 | HP LaserJet 2420 Printer
Tip
How to solve 10.00.00 memory supply error
Memory Supply Error 10.00.00
The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the toner cartridge as it is inserted into the printer. The probes on the E-label reader make electrical contact with the chip, which pass along information to the printer with respect to Toner Life and number of prints made etc... If the printer is unable to read the chip for any reason an error is reported. The error is common to many varieties of HP printers
1 - Make sure the toner is firmly seated into the printer.
2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer.
3 - Install another toner cartridge.
4 - Verify that the e-label connector is firmly seated in connector.
10.00.00 Troubles shooting Link GOHERE
Contact a local HP Authorized Service Center for further assistance.
on Feb 23, 2011 | Office Equipment & Supplies
The printer is giving me service error E527 what can be done to overcome this error
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Nov 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
10.00.00 supply memory error
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Oct 14, 2010 | HP LaserJet 5200 Printer
10.00.00 supply memory error Unable to read cartridge data
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Sep 01, 2010 | HP LaserJet 2420 Printer
SUPLY MEMORY ERROR
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector.
Aug 17, 2010 | HP Hewlett Packard LaserJet P3005 Printer
My hp laserjet 1210 mfp always reads supply memory error.. what is that?
Aug 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please
Aug 03, 2010 | HP LaserJet 5550 Printer
10.1004 SUPPLY MEMORY ERROR ON IMAGING DRUM Unable to read the supply data. Re-install the supply. If the error reappears, contact support.
Jul 03, 2010 | HP LaserJet 2840 All-In-One Printer
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector J510 on the ECU. You might have to remove the main cooling fan.
May 26, 2010 | Laser Jet P3005 series Printer
HP Color LaserJet 5550hdn Printer Logo
152 people viewed this question
Seeker5211
Seeker5211
