Question about IBM ThinkPad 390X 2626 Notebook
Blank screen truns on screen is blank
  • 78 Answers
Can you check real close if the screen is very faint instead cause if the illuminator is gone then you might just need to get that fixed instead of the whole screen.
Posted on Mar 10, 2009
My acer v5 has a blank sceen
There is hardware issue, if you have a little bit knowledge of computer hardware and have a tool to open it , then trun the laptop and open the screw of ram portion to clean the ram. if this will not work for you then please consult with it expert chipset level computer engineer.
Sep 22, 2014 | Acer Aspire V5
Husqvarna viking diamond deluxe embroidery machine main motor overload
I'm not familiar with the Diamond machine but suggest the following. The motor is overheating. Is the sewing machine cord plugged directly into an outlet or are you using extension cords? Voltage drop due to long or light duty cords can cause the motor to run hot.
Can you trun the handwheel freely? If not, there is friction or binding in the machine that needs to be corrected. The blank screen and reboot are simply protection devices like a circuit breaker in your home electrical circuits. Find the source of the problem!
Mar 23, 2013 | Husqvarna Sewing Machines
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
I have hp pavilion dv4 1070ee. window vista. i was trying to update my bios but everthing went blank. i trun off the laptop and try to turn it on agian but still bank screen. i don't know whether the...
Turn on and keep pressing the F8 key
If nothing shows up on the screen after a minute shut down, restart & kep hitting the F10 key
A recovery screen should appear by pressing one of these keys
If the screen appears pick a recovery job to restore your computer to a day when it worked well last
Jun 30, 2010 | HP Pavilion dv4000 Notebook
LCD Screen blank
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Acer AL2416WBSD 24" Monitor
My ps3 isnt showing anything, its just blank whenever i try to trun it on the screen is just blank, but when i put a disk in, i see a little loading circle on the top right hand corner any help will be...
HOld the power button down while its on for 10 seconds. DO this 2 or 3 times. you will hear it beep once, do NOT let go hold it for the FULL 10 seconds to do a full RESTART!!! That should help you out.
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
My intendo ds wont trun on it stay blank
you need to check to see if the battery is charged, this is a normal indicator the battery is dead. Charge until the light goes greeen
Mar 30, 2009 | Nintendo DS Console
Screen truns blank after starting up
Check the caps all eight and the 5v transistor it's seem like it braking down under a load (heat up and shut down)
Mar 11, 2009 | Gateway FPD1975W 19" LCD Monitor
Sansa e260: Blank Screen
Got it working, I held the Power button down for aprox 30 seconds until the dial light went out then it restarted as normal..
HTH
Nov 12, 2007 | SanDisk Sansa e260 MP3 Player
IBM ThinkPad 390X 2626 Notebook Logo
114 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
