Question about Panasonic DVD-S53
My RCA high fidelity CD/RECEIVER (Model CR -
My RCA high fidelity CD/RECEIVER (Model CR - 2010F has the following problem
The CD drawer does not open. Can anyone suggest solution?
    New Friend:
The door was pushed in to far you have to pull the door out gently why you pushing the eject bottom.
Posted on Apr 11, 2013
  • Janos Czifra Apr 11, 2013
I am not getting a bluetooth signal from my car stereo. Can this be fixed?
Does specification of your cr stereo say it has bluetooth? If it says, does it has a switch-on function? Look at manual, in setting! Once bluetooth is on, it should start sync with other device, headphone ir speaker, presume
Apr 12, 2015 | Car Audio & Video
Crosleycd disk will not eject
To manually open CR 248 CD drawer take a butter knife insert it under the drawer and above the "C" in the word CD recorder. I polked around for the button and it opened. Did this several times and it's working now thanks to another post on Fixya.com! Yay!
Sep 14, 2014 | Crosley CR2405A Mini Audio System
How do i assemble a pinoeer stereo system model VSX-504s and model CLD M403
Use RCA audio cables to connect the CD player to the receiver. The CD player should have two RCA jacks labeled "audio out"; On the top row one jack is red and the other white. On the Pioneer receiver in the back, there's several rows of RCA jacks. On the bottom , just to the right of "tape monitor"it is labeled "CD". Plug the red RCA cable into the red jack on the bottom and the white plug into the white jack on top of the red jack. On the front panel of the pioneer receiver is a small button labeled "CD". Press that button to listen to the CD's.
images?q=tbn:and9gcrfpubn4rfeo_gjllmgnn8g_iqmawgbbh3jscq6cfxrh7y-3f7qegThe red cable is fro the right channel ( right speakers), and the white is for the left.
Jun 06, 2014 | Televison & Video
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
C0910
Hello
C0910 shows that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there's any jammed paper.
Mar 04, 2011 | Minolta DI-2010F Copier
I need to know how to go hook up my reciever to my tv soo i can get sound from the tv..
Get the audio from the same place the TV does - your cable/satellite box. It will have an RCA Audio Out pair. Run it to any available input such as CD, Tape 1 In, Tape 2 In, Video 1 or Video 2 In.
If you're already using that output to theTV just get a pair of RCA cable splitters and share it with the receiver. That way you can watch TV and listen through its own speakers (news and such) or turn the TV volume down and select the input on the receiver for better audio.
What you DON'T want to do is actually run audio through your TV and its questionable audio electronics into your hi-fidelity receiver.
Mar 17, 2010 | Onkyo TX-8511 Receiver
CD drawer will not open
Hi
maybe you have defective mechanical ejection! maybe the lock is stock. this is need to open to hook up the lock
thanks!
Likha
Oct 23, 2008 | RCA RCD150 Radio/Cassette/CD Boombox
Philips High Fidelity reel to reel recorder
Shot in the dark - there is an individual who does this professionally with the Philips reel to reel - may have info for you
(BTW, do not mention that I sent you - this is a secret tip)
victor@victorives.com
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Drawer came off track
You need to open it, lift two tabs at the back of the tray on each side to allow you to remove it, then re-insert making sure it's back on the rails.
Mar 10, 2007 | RCA CDRW120 2-Disc CD Recorder
Panasonic DVD-S53 Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
