Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
  • dougmcduff Apr 30, 2009
    Kitchenaid KHMS155LSS-3 comes on by itself periodically and runs for 3 minutes. Display reads "Pan" and beeper sounds intermittently. Tried removing power to reset controller, but problem remains.
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Posted on Jan 13, 2011
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Having touch-pad problems with my KitchenAid KHMS2056SSS-0 range hood microwave. It's an intermittent problem where the touchpad activates itself and activates menu items.. and beeps each time. Resetting...
Usually the top vent front panel is held in by two screws and or clips, Get those off and the bottom of this peace should un hook, unless there are screws there also. if you can get this far, the rest will be obvious.
Oct 20, 2013 | KitchenAid Microwave Ovens
Starts by itself. beeps constantly when on. locks up in pan mode
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On many Kitchenaid models, the keypad is not available as a separate part and you have to order the plastic control panel frame / subassembly (depending on model number) which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Jan 16, 2011 | KitchenAid Microwave Ovens
Microwave starts on its own and displays PAN
I'm contacting you directly.
May 22, 2010 | KitchenAid KHMS155L Microwave Oven
Kitchenaid ykhms155lss need to take off broken handle for replacement...how to access?
take screws out of side then use flat butter knifes to hold the push pins out of the way so glass comes out then get to the handles
Feb 04, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave will turn on by itself and display PAN on screen.
Does everything come on by itself or is it just a fan that comes on? If so, is it a convection oven?
Sep 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave turns on randomly beeps intermittently displays PAN
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it and please reply back with your model number so we can help you.
Sep 07, 2008 | KitchenAid Microwave Ovens
Built in kitchenaid microwave starts beeping, then won't function. flipping breaker helps sometimes, but other times it doesn't help.
to bsm
When this happens, what is shown in the display? Is it the same displayed info each time?
This is usually a failing membrane keypad, but your reply will help me know if it's that or some simpler.
We're happy to help and we appreciate your thoughtful rating of our answer.
to Guest
Since yours is a different problem, please repost as a separate message and include your brand and model number.
Jul 03, 2008 | Microwave Ovens
Microwave beeps, error codes display and keypad stops working
It sound like you have a bad keypad or controls.
Is it possible that moisture from the sponge is getting into the controls?
You might contact the manufacturer to see if there might be a recall. I've seen keypad recalls in the past.
Anytime the keypad is suspected of coming on by itself, the oven should be unplugged when not in use.
Jul 01, 2008 | Cuisinart CMW-100 Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
701 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
