Question about Toshiba Satellite A45-S120 Notebook
Recovery **** when I go to run my recovery disk I hold c apon start up. when i get to the screen that says hit F1 ok or F2 to cancel I hat F1 and nothing happens. If i hit F2 it goes to e:\. How can I get in to run?
  • kywhaley Mar 11, 2009
    Holding C goes to the same screen as holding F12 then selecting cd rom. it does not give a press any key option it only ask to hit F1 or F2. the F1 function to run the reboot doesn't seem to work.
  • kywhaley Mar 12, 2009
    It is the reboot disk that came with the notebook. The F1 key works. just not to prompt the disk to do it's thing. is there a comand I can use from the E:\ screen that might start it?
    Master:
  • 404 Answers
This isnt a MAC so C wont help. click f12 then select CD ROM to boot from it. then it will ask "press any key" then do that. ....the rest figure it out yourself
Posted on Mar 10, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 11, 2009
    are you sure your CD is bootable? and it works elsewhere
  • lotfi bouakaz
    lotfi bouakaz Mar 12, 2009
    there isnt a comand, did you go tot he bios and set your first boot device as the CD rom or the DVD rom? so it boots from there first.
    normaly you get f1 request when your battery for the bios is dead.
Bad hard disk message back up and replace message
If the hard drive is failing it will need to be replaced and then you can use the recovery disc to re-install windows. If this computer is newer than 2005-6 then it most likely uses a 3.5" SATA drive.
Dec 18, 2012 | E-Machines eMachines Desktop PC
Hi, I have a netbook running Windows XP. When I start it up it has a white screen with the manufacturer name, at the bottom it says "Press F2 to run setup, Press TAB to display BIOS POST...
I'm afraid that you'll have to get some installation disks for an operating system and boot from it using an external DVD drive (for Windows 7 for instance). If System Recovery doesn't proceed, that's the only way I know to load an operating system.
Dec 18, 2010 | Computers & Internet
It went to welcome screen and after i typed in my password, got a black screen that says insert disk and press F1 or press F2 and something about setup.
This happens whenever one closes any installation prematurely. Insert the disk then properly cancel or complete the setup and restart the computer you wont get this message.
Jun 22, 2010 | Dell Dimension 2350 PC Desktop
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
The instruction at "0x77d4bbcd"referenced memory at "0x00000048".the memory could not be "read" click on OK to terminate the program click on CANCEL to debug the program
This error comes when there is issue with harddisk clusters.
First open cpu cabinet and find motherbord.
Refix RAM memory.
Then boot computer with windows disk or recovery disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios screen.
Then go to boot option and set first boot device as your cd/dvd rom .
Then save settings and exit.
Then insert disk in cd/dvd rom .
Then it boot with that disk.
Then follow the procedure and enter in recovery console mode.Then type in prompt "chkdsk /r"
then press "y"
Then it fix error on harddisk.
Then check.
If still same error then you have to repair your widnwos.Follow the above procedure again and this time choose "R" option for repair previous windows.
Let me know if you need more assistance.Thanks.
Nov 07, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Vista will stop after sign-in at a blue screen. Runs in Safe Mode OK.
First open cpu cabinet refix RAM memory.
Then when you power up the computer press F8 key then enter in safe mode.
Then go to start menu then type in run "chkdsk /r"
then press "y"
then restart then it fiox error on harddisk.
Then if still same issue then you have to need recovery disk.
Boot your computer with recovery disk and then repair your vista.
For booting when you power up the computer press F1 or F2 or "del" then ente rin bios .
Then go to boot option and set first boot device as your cd or dvd rom then save settings and exit.
Then put recovery disk so it boot with disk.then follow the procedure then repair vista.
Let me know if you need more assistanse.
Thanks.
Sep 13, 2009 | E-Machines eMachines Desktop PC
My sons dell e520 wont start . i get the windows starting screen then it switches to a black screen with the messag floppy diskette seek failure then the options f1 to continue or f2 to run the set up...
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
Nov 29, 2008 | Dell Dimension 4600 PC Desktop
Reinstall from the recovery disks
To ge into de BIOS hit:
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Nov 18, 2008 | Sony VAIO VGN-S460 Notebook
Screen brightness
well in bios hold f1 f2 to get in it u know u can adjust most screens britness in ther on the battery adjustment britness on battery power and off battery power ok if not u can dl software that adjust britness within windows what labtop u own what kinda video card in it thx nick im open for chat
Jan 07, 2008 | Sony VAIO FX150K Notebook
Toshiba Satellite A45-S120 Notebook Logo
138 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
