Question about Hardware & Accessories
Need timer motor
''I need a motor for an old style mechanical timer with fold out time settings''
  • 52 Answers
Posted on Feb 26, 2010
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Will not spin
Does the machine attempt to spin or wash? These are the last of the lawsuit generation where the motor control board circuitry failed, most likely blowing the fuse. Unplug the unit from the wall, open the door and remove the 2 screws on the left and right (2 will be holding the hinges on) close the door and gently tug on the top corners of the front panes, look down to the lower right floor of the inside of the unit, does your motor control board have the white or clear plastic sheet folded over it, or it is a solid yellowish plastic housing? The control board with the white or clear plastic sheet is the old style, and mote likely needs to be replaced. there is an on board fuse that will blow. The parts needed are serial number dependent, so your serial number will need to be provided. Pleazer Appliance...
Old Style
New style
Apr 18, 2014 | Maytag Neptune MAH7500WH Front Load Washer
Red devil 5400 electrical connections
Your best bet is to get the mechanical timer kit. It eliminates the problems with the old circuit board style timer, by making it all much simpler.
Nov 20, 2013 | Red Devil 5400 Heavy Duty Paint Mixer
Pool pump clock
T104M used WG1573 clock motor:
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
1 year old t101m timer stopped working. The manual on/off works but mechanical clock doesn't. Is there an easy fix or should I just repalce?
T101 dial is not working so the 125V clock motor needs to be replaced:
Grainger sells 125V T100 series clock motor:
Timer mechanism releases from box with metal spring located inside top of box.
Clock motor is attached with 2 star screws.
Notice clock motor has plastic gears, but timer has metal gears.
Metal gears on timer mechanism last for many years.
Notice also that clock motor wires connect to terminals A and 1.
After installing new motor, tighten screws very tight against copper wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | RTO Intermatic T101M Timer Mechanism Only...
The dial on the intermatic water heater timer is not rotating on it's own and is easy to turn in either direction-without pulling it out and setting the time. The unit is only 1 year old..Can I replace the...
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
Electric supply online sells clock motors
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
T101 and T103 use 125v motor
T104 uses 240v motor
Dec 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
Nov 20, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Clock does not work to turn pool filter on and off. do I need a new timer mechanism or clock motor
Things to check:
1) Is yellow dial rotating? If not, then clock motor is probably bad. T-100 240V time clock motor sells for $16 at grainger.
Also timer may not be getting 240V so check manual override.
2) If clock motor is turning, but manual override never clicks on-and-off, then pins are probably worn out. Buy pins at grainger
3) Does manual override work? Does it click crisp? If manual override clicks crisp on-and-off, and pool filter turns on-and-off normally, then a) the circuit is getting 240V and b) the timer mechanism is ok ... so clock motor is probably bad.
4) If manual override snaps crisp but pool timer does not turn on, then then circuit breaker could be bad, wire is loose, motor has gone bad
Test for 240 across poles 1 and 2
... or timer contacts are worn out & you need new T-104
See back of mechanical timer
5) If manual override is loose or sluggish, then you need new T104. You can buy a T-104, T-104R, T-104M etc ... and the interior body will snap into old box.
Note: Do not buy T-101 or T-103 as these have 120V motor.
Sep 29, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Clock Stopped Turning
Most likely, the timer motor has failed and needs to be replaced. As the timer motor is constantly running 24/7, getting 19 years of use is significant and is well beyond the typical life of a mechanical timer of this type. I know, I've got the same ones on my pool and usually have to replace them every 10-12 years.
As the timer IS 19+ years old, it would be best to replace the entire unit instead of looking to tyr to get just a replacement timer motor, since the cost for a new timer isn't all that much compared to the cost for just the motor.
Intermatic also makes a digital timer version of this type of timer, but for the relatively low price of a new, replacement mechanical timer, it might be a good idea to get another one like you have and expect another long working life.
Sorry that there really isn't much to repair in such an old timer, since the motor is the critical part.
The replacement should be easy to do yourself, just remember to turn off the power breaker and disconnect the power to the timer. All you need to do is exchange the wires into the new replacement timer I find that taking a picture of the timer as it is, will help you get the connections correct for the new timer.
Also, check the model number of your present timer and voltage, (some pool equipment is 100V-AC while others are 220V-AC) to get the correct replacment timer.
Hope you find this Very Helpful and best regards.
Sep 09, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Hardware & Accessories Logo
85 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
