Question about HP OfficeJet 6110 All-In-One InkJet Printer
Roller squeal? HP OfficeJet 6310 all in one series
When printing it sounds like the roller is squealing, like it needs to be oiled or something. any suggestions?
  • 1 more comment
  • melscooking Mar 11, 2009
    Is there a suggested way to safely do that without ruining my machine? What type of oil? What do you use to squirt/apply the oil?
    Genius:
  • 2,120 Answers
It could be the chrome plated shaft the cartridges ride on. Lube with oil.
Posted on Mar 10, 2009
HP Laser 6L - Printer makes a squealing noise but does not advance the paper to complete the print.
Old age printer, it needs to replace feed roller assm,pick up roller & separation pad to avoid pickup issues.must be replace these item at a time to avoid tension.
Sep 23, 2011 | HP LaserJet 6L Printer
My printer squeaks/squeals when its printing. Any ideas? Thanks!
Sometimes squeaking can be caused by the toner cartridge. Try reinstalling the cartridge or installing another. This cartridge's yield is 2500 pages. When is very used, it could make rare sounds. Always use genuine HP cartridge.
The arm of the pick-up roller is loose... is normal.
If the pick-up roller have a very smooth surface, replace it. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 24, 2010 | HP Photosmart C6100 All-In-One Printer
Canon Pro9000 MarkII roller squeal
You do not use lubricant on printers. Clean all roller and bars with Q tip and acohol. Make sure alcohol is squeezed out so it does not drip inside printer. The noise should stop. If it does not it is the belt that drives the capstans (rollers) that is worn out.
May 28, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
The paper feed appears to be broken some how -- it does not take the paper
Remove the paper from the tray.
Look inside the tray and you should see a roller on a arm
Clean that roller with some surgical spirits or nail polish remover
Replace paper and try to print.
Good Luck
Apr 14, 2010 | HP Officejet 6310 All-In-One InkJet...
I have a dryer that is making squeal as the
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Dryers
My HP Officejet 6310 makes a squealing noise when printing, like the roller needs oiling-any suggestions on what to do?
turn off the printer..connect the printer to wall outlet..and try to make a copy..if its still the same..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold OK and CANCEL button together..
3)while pressing these two buttons plug in the power chord to the back of the printer..
4)after you plug in the power chord do not release those two buttons..
5)keep pressing those two buttons till the screen goes blank..
6)once the screen is blank release the buttons and turn on the printer..
7)wait for the printer to get initialize..
8)once the initialization is complete..try to make a copy..if the printer is still making noises..then machine should be replaced..
let me know after you perform these steps
Mar 10, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 2100 makes squealing noises
It could be a roller, a drum, sometimes the auger in the cartridge can do it.
Should have a technician look at it to find specifically where it is comming from.
Jun 13, 2008 | HP LaserJet 2100 Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
271 people viewed this question
Ben Johnson
